Plane Blade Flattening
Haakon
>Yesterday I decided to give my LN block plane plade a decent tune-up (been planing some Iroko, apparently full of sand, plus other abuse). So I started by giving the back a serious go with silicon carbide paper (120) on a flat and wet granite slab. I went through successive grits and finally put it to my Norton 4000 and 8000 grit waterstones. At the end the back shone like silverware.
However, to my surprise, the edges seemed to have been rounded somewhat. To me it appears that the blade was literally "digging" into the paper thus the paper was somewhat lifted off the granite on both sides of the blade hence rounding the edges. What's worse is that the rounding gets more pronounced towards the blade edge.
Now, it could be the stones not being flat, however I flattended them before starting plus the unpolished areas clearly bears the unmistakable marks of the paper.
I decided to redo the whole thing, this time using entirely the waterstones and the results were fine, except for the perhaps excessive wear on the low grit stones.
Any suggestions on how to avoid this problem (and at the same time saving my waterstones)?
Thanks
Haakon Haraldsen
Reggio Emilia, Italy
