Block Plane Rack
Block Plane Rack
Block Plane Rack
todd stock
>Missed the discussion on this the first time, but here's a shot of what I'm using for short trimming planes.
Sides of rack are an 8" square 3/4" ply split on the diagonal, while surface is 1/2" ply with 3/4 x 5/8 bottom strip and 3/8" x 1/2" divider strips. 45 degree slope works fine for small top-heavy trimming planes. The fence for the LN skew rabbet is at right - keeps it out of the way but available.
I'm not paranoid about whether the blades rest on the ply; however, a couple of cork or softwood srips would take care of the problem.
Todd
Re: Block Plane Rack
William Claspy in Cleveland
>Nice rack, Todd :-)
That looks like a design I could use in my shop.
Bill
todd stock
>Don't recall hearing that particular complement addressed to me before, but thanks!
Jim in Burlington Ont.
Jim in Burlington Ontario
>Hi Todd what kind of plane is the silver one in the middle. Thanks Jim
todd stock
>Jim:
Nothing special (too bad!), although looking at the shot it's hard to tell it's a late model Stanley #79.
Todd
>I like it. I think I have five of the planes displayed - would you care to list them?
todd stock
>Let me see...from right to left:
9-1/2 LN Adj Mouth Block
60-1/2 LN Low Angle Adj Mouth Block
9-1/2 Record Block
140 LN Skew Block
102 LN Low Angle Block
79 Stanley UK Double Side Rabbet
100-1/2 Wood River Bronze Round Bottom Plane
97-1/2 LN Small Chisel Plane
212 LN Small Scraper
95 LN Edge Trimming Plane
1/2" LN Infill Small Shoulder Plane
Think that's it. Bench planes are above, and mounted at a lesser angle, with the 1/4" baltic birch ply heel guard set up to prevent anything from spilling without resorting to turn-buttons or toe hooks. Not really fancy, but I've got too many other projects running to spend much time polishing a utility project.
Bench Plane Rack, too.
>It looks like a handy setup. I have not seen anyone make cutouts like that for the shorter bench planes. Good idea. What angle did you use for the back? Would you make it different if you had to do it again?
BTW, do you have differing roles for the two 9�'s?
Re: Bench Plane Rack, too.
todd stock
>Don:
The rack is 27" high with a 7" (approx) kick out, so about 15 degrees - enough to keep things put but still easy to get at. I used two 3/4" birch ply supports for sides and 1/2" birch for the base. Ledger strips are 3/4 x 3/4 stuff or 3/4 by 5/8 between tools.
One option might be to top-mount the bench plane section on a heavy piano hinge to give storage for extra blades, frogs, etc. Another might be to extend it in width to 36 or 48 inches, but I'm one of those guys that is fairly content with the 8/5/4 plus specialty mix.
That said, I still left slots for another 5 (an additional set up for York pitch), maybe a 4 set up for common, and possibly a bronze 3 (I think it's the best smooth plane for inboard joinery work on boats).
I use the Record 9-1/2 for carpentry where nails are a threat and the LN 9-1/2 for finer stuff. I've beat the Record to death since 1980, and it's still hanging in there. The old style Hock blade seems to chip less on nails than any of the others I've tried, so it's my choice when trimming near fasteners.
FWIW, I use the LN LA jack and the 60-1/2 almost exclusively on softwoods or stuff like mahogany where the low bedding angle seems to work. For tough stuff, I've been really impressed with my old pre-production LN #4 retrofited with the new HA frog, cryo blade, and improved cap iron - ultra curly maple now planes like rift cut plain vanilla cherry.
Todd
