Lee Valley "Plywood" Saw
Dave (Arlington, VA)
>Hi -
I've noticed that Lee Valley carries a Japanese-styled saw they call a "plywood" saw. I've been doing a fair amount of plywood work and I'd like to find a saw that holds up and works will in the mixed-grain and glue environment of plywood.
Has anyone had any experience with these saws. Does it leave a smooth cut? I can't recall any discussions of them here at Wood Central. If so, my apologies.
Also if anyone has this saw, do you know the TPI, set and tooth configuration of the saw? If I recall correctly, I believe Lee Valley says the teeth are specially hardened, but is there anything else about the saw that makes it better suited for plywood.
More generally, does anyone have any other recommendations for handsaws and plywood (other than be prepared to sharpen it alot) - e.g. TPI or tooth configuration.
Thanks -
Dave
