Plexiglass and diamond paste flattening
Sanford Levy
>Has anyone tried laying a piece of plexiglass, or other plastic, down on a flat piece of plate glass for flattening the backs of planes etc with diamond paste? The glass is flat, and the plexiglass on top will therefore be. But the plexiglass is sort of soft so that the diamond bits can (I assume) stick into it the way (as I understand it) you want for flattening yor plane. (If I understand right, the inability of the particles to stick in regular glass is one of the problems with diamond past on regular glass. The reason some people use a maple block is so that the particles will stick nicely.) You could use a separate sheet of plexiglass for each grit so there is no problem of contamination. If the plexiglass wears out it can be discarded. It is not very expensive anyway. I have not tried this, and it may be one more of my dumber ideas! Sanford
Re: Plexiglass and diamond paste flattening
Any diamond pasters got your eyes on?
Edward Damewood, Northern Alabama
Bill Tindall, E. TN
>If you can keep the plastic flat it should work ok. I predict the diamonds will embed deeply and therefore be less aggressive than diamond on cast iron (at least this was our experience with wood), not a bad result , just different. The plastic will be harder than wood and that is good. I didn't understand the other post, but if he is looking for diamond paste, Travers has it on sale till end of Jan at a significant discount. Let us know how it works.
