OT - Hanging a rug
OT - Hanging a rug
OT - Hanging a rug
Matt -- Los Angeles
>Hey all,
I've go this rug that's about 5 ft. wide by 3 ft. tall that my wife and I want to hang above our bed on the wall. We live in California where one doesn't hang heavy objects above beds.
The question is how can I support this rug which weighs about 15 lbs. without opening up the weave or pulling on the stiching by way of hooks or some such method. I'm thinking of mounting it to a pice of 1/4" masonite but it needs to be supported pretty much everywhere.
anyone have any experience?
Thank you in advance
Matt
Re: OT - Hanging a rug
Charles McKinley (Harrisville,PA)
>Hi Matt,
Go to a private rug dealer and you can probably get them to sell you the hanging clips that they use. If you hang it vertically you should be able to get away with 3-4 clips, horizontally 4-5 clips. I helped out at a persian rug dealer for a couiple of months. If it is a really good rug, in good condition, hanging it this way should not weaken the weave.
Good luck
Chuck
>If you've got heavy enough needles available, sew up a tube from some heavy cloth of a suitable color (fabric stores usually carry canvas in multiple colors) by looping it over, sew it to the rug all the way along, and then put a rod through it; hang that from curtain rod brackets or brackets that you make. PUt some sort of finial on the rod, so it can't slide sideways, and, if you're concerned about it bouncing off in an earthquake, put a screw through the rod down into the bracket at each end.
Clay Craig in Miami
>If this is not a museum piece, here is a very simple solution (I have lots of hanging rugs - the floors got full too fast!).
Cut a length of the 'tack strip' used to hold/stretch wall-to-wall carpet, to the width of the 'top' end of the rug. Attach that to the wall however it suits you, with the tacks pointing out and up. Then, just press the top inch or so of the 'pile' part of the rug onto these tacks gently (if the rug has a woven-but-unpiled webbing at the end, do not put the strips through this). These tacks are spaced closely enough that no one part of the rug gets much stress put on it. For you, this has the added benefit that you can solidly attach the strip to the wall, and it doesn't weigh much anyway.
One other tip - All handmade rugs have a 'grain.' The tufts do not point up perpendicular to the warp and weft, they point to one end - the end that was at the bottom when the rug was woven. So, if the rug is handmade and is end-to-end symmetrical (or if you don't care which end is hung 'up'), then always hang it with the grain of the rug running 'down' - i.e., so that it feels smooth when running your hand down the rug, rough when running you hand up it.
This helps a LOT in keeping dust from settling down between the tufts - dirt down there is what abrades the knots and structure, and makes a rug wear out before its 4 centuries are up.
(I learn so much here, and am such a wood rookie that I can rarely help anyone out - nice to hit a question I can address!)
Clay
Quilters know how
Gary Miller
>My wife is a quilter and we hang both persian rugs and quilts on the wall with a wooden "clip" that is sold at quilt shops for this purpose. They come in ash and walnut, so you have a light and dark choice. Inexpensive, we use several on each hanging, depending on weight of rug/quilt.
Gary
Great answers...thanks all...
Matt -- Los angeles
