Advice on scraping tiger maple
Lance
>Greeting,
I'm working on a tiger maple harvest table and hutch. This is my first time using figured maple and am wondering on how to finish it so that it looks "dated" as to opposed to "new". Would this be a time to use a scraper plane as opposed to sandpaper? If so, what is the process? Draw some light lines on the surface and scrap them off to keep a uniform finish across the surface? Do I sand lightly after scraping? Any advice would be appreciated!!
Thanks,
Lance
Re: Advice on scraping tiger maple
Wiley Horne--Glendora CA
>Lance,
Am sure the harvest table and hutch will be wonderful pieces when done. Don't want to change your mind on anything you're doing, but I'm just finishing a curly maple project, and will offer a few observations for what they're worth.
The finishing procedure will affect the final look far more dramatically than the raw wood preparation--including whether it looks aged or new. You mentioned that this is your first time using tiger maple, and believe me, when you hit it with the finish, it's gonna do some amazing things. The sequence I have followed is one generally recommended by Jeff Jewitt and also our own Dave Anderson: dye the raw wood to set the basic color tone; rub in boiled linseed oil (or tung oil or walnut oil, whatever) to pop the curl in the figure. From there, you have many options for a top coat.
There is an excellent article on Jeff Jewitt's site (www.homesteadfinishing.com), titled 'Early American Maple Finish', which shows several different possibilities. You'll find it in the 'Articles' menu.
I think you will see from Jewitt's article that the maple takes on a look of great character from the finish treatment. This is most noticeable, not so much when you do the dye treatment, but rather the minute you put the oil on it. When the oil pops the figure, it gives it a depth and takes the 'new' out of it right there. It will look great if smooth and glowing, and distressing is very risky and may detract IMO.
Wiley
Jim in Burlington Ont.
Jim in Burlington Ontario
>Don't be disappointed if you can't scrape it all perfect it's tough stuff to work with. I personally love analine dye's and polymerized tung oil.
