Silicon carbide power on metal plate
Sanford Levy
>I decided to try flattening planes on metal plates from Japan Woodworker using silicon carbide. Can rough grits be washed off well enough to allow me to use one plate for all the grits? I know with diamond paste, you often need several flattening surfaces, one for each grit, especially if you use a soft surface like maple. I have no idea how likely it is that bits of silicon carbide will stay stuck in the mild steel of the plate after it is washed. Thanks. Sanford
