Review of Knight jack and smoother w/pics
John K in Hastings, MN
>Sometimes you love government workers, like when the mailman comes to your door with a box from Knight Toolworks. Here's what it looked like after unpacking:
First impressions are WOW, boy these are good looking, and bigger and heavier than I expected. Both are of padauk with ipe strike plates and throats. The smoother is bedded at 50 deg, and the jack at 45. The blade is A2 steel, very thick, and already honed to a mirror finish. There are hex screws in each side near the sole to center the blade in the opening. I couldn't wait to get them out of the cold and into the shop.
I figured a good first test would be the "straight outta the box" test. I couldn't think of anything more frustrating to plane than birdseye maple, so I put a piece on the bench and tried the smoothing plane first. It was tuned and used prior to shipment (see curlies in photo above) and it turned out to have not moved a bit. A couple passes, and this:
The curlies are very impressive, and don't mind the missing chunks in the shavings because the planer had already torn a bunch of eyes out. Obviously, it was time to pull out the jack plane and smooth the planer marks out first. The jack had shifted in shipment, and it took a few minutes playing with the throat adjustment and blade to start taking nice long ribbons:
After adjustment, it took just a few passes to flatten the surface, after which the smoother took very nice thin passes with very little tearout. Even that I'm not sure is due to the planes as the tearout from the planer could be pretty deep.
I'm really happy with these. They look great, work great and I haven't even taken time to get them fully tuned yet. They are well worth the money, Steve does a great job and I enjoy his posts here.
John
Re: Review of Knight jack and smoother w/pics
Steve Kubien
Tool Drool
Steve Kubien
>Hi John,
I've got a pretty good case of tool-drool goin' on over here! I have the same smoother (except 45 degrees) but I REALLY want the jack as well. Nice pictures too.
Looks like another fine job by Knight Toolworks. Enjoy them John.
Steve Kubien
Jim in Burlington Ont.
Re: Tool Drool
Jim in Burlington
>John I see luck has shined upon you. I have never seen one in person how thick and wide is the blade? Dreaming in -20 temps here.
Re: Tool Drool
John K
>If I recall correctly, the blade is 2.5" wide and 1/8" thick. Nice and heavy.
John
Re: Tool Drool
Steve Knight
>oops better get this corrected. the irons are 2" wide and 1/4" thick O-1 steel. the wood is padouk.
Steve Kubien
Hey Jim
Steve Kubien
>Hey Jim (or anyone in the GTA),
If you are going to be out in my neck o' the woods, come on over and take my smoother for a test drive. Let me know.
Steve Kubien
Ajax, Ontario
Re: Hey Jim
Jim in Burlington
>Thanks for the offer.
Mike Schwing from Md.
>Those planes of Steve's are works of art. I have a purpleheart jointer that is smooth and sultry looking, and it performs just as great as it looks. I almost feel guilty making a comment about it, but here it goes; I see it on yours as well - the area of the handle joinery just isn't up to par on a visual scale with the rest of the plane. It almost looks like it was built by a different person and added on as an afterthought. The screw popping up out of the top, it just doesn't do the rest of the plane justice. Every time I hold mine up to a workpiece, or just to admire it, my eyes run from the smooth lines at the toe all the way back to where they are interrupted by that "butt joint" handle with the screw sticking out.
Am I picky? Yes. Could I do better? Heavens no.
I really love that plane I have, and yours, too. Handle joinery just doesn't fit with the rest of it.
>I dunno John, loks kinda' clunky and appears that it would be uncomfortable to hold. Best send it to Florida where it is much warmer fir analasis. ;~)
sorry Steve, but I do have to agree with Mike on the issue of the handle joinery, otherwise your planes are absolutly gorgess, and I am very envious of your abilitiy to make them.
Todd O.
Steve Kubien
Steve Kubien
>I think offers both the jack and jointer without the handle (basically shaped like the coffin smoother but longer). Does anybody have one of these and if so, how is it to push that much plane, taking heavier cuts without a tote? Feel free to ping me off-line if you see fit.
Thanks,
Steve K
Lyn J. Mangiameli
>If I remember correctly, those handles don't come from Steve or at least they didn't used to, but are/were made by someone else who offers exotic wood handles. So your observations may actually reflect reality
Steve Knight
>work of art? well I doubt it (G) at the time I did not have the tools to chop a mortise into a plane (sure can't do it by hand tools) and a stanley tote was affordable and replaceable.
but if they were morised in there what would be a good way to do it so they could be removed?
wht about the tote it's self does it look alright?
Steve Knight
>Almost forgot. I debate on if a mortise machine can hold up to chopping mortises in purpleheart and ipe cocobolo ebony and such.
>Steve, I sure don't want to add to the manufacturing cost of your lovely planes, but I'll see if I can elaborate a bit, since I brought it up.
PLEASE don't this personally, I've tried to take care to make sure you know I LOVE your planes.
Some of my comments will be simply personal preference, others might be considered objective critique. Which are which? Heck if I know.
The tote's overall proportions are fine, The front area of the foot of the tote, on mine and on the one in the picture, has a vertical surface of about 1/4" that joins a beveled horizontal surface. If that area were smoothed to match with some of the other curved surfaces on the body of the plane it would help make a clean transition from body to tote. Personal pref - I don't like the appearance of the front tote screw sticking up out of the tote, it should be recessed into the tote, as is the top screw, IMO. Messes with the lines. Yes we (you) are making planes here, but yours is so close to a work of art I'd love to see it taken the next step.
As others indicated, and you did, too, a slight recess/bed for the tote would be mostly all that is needed to complete the picture. I can envision a dedicated router jig that would hold the plane upside down over the top of a 1/2" straight bit to make the recess. I'm unaware of your volume but can't imagine a few quick swipes to make an 1/8" recess would eat too many bits.
I'm sure this last one is purely personal preference, but since there are no hard lines on the rest of the body, I'd also like to see none on the tote - the top edge could be rounded.
I feel so guilty even discussing this. I'm glad you're open to it.
>I have never used a mortise machine on anything harder than oak, but maybe you could help it out by drilling out most of the waste on the drill press, and then cleaning it up on the mortiser.
Electron Police: We are doing this to a hand tool!
Frank Mutchler
>Steve, how about joining the tote to the plane body with a sliding dovetail? That would allow the line of the tote to meld seemlessly with the body??
Robert Weber
>I was going to recommend the sliding dovetail as well. It would not need to be glued as the pushing on the plane would keep it in place, which would also make it removable. The screws definitely look out of place on the rest of that gorgeous plane.
Rob in Peoria
www.geocities.com/robntweber
>Other than they looking like a bit of an after tought the totes themselfs looks fine to me Steve. I hope you do understand that I said that in the Spirit of constructive critisism only. I like other have already said think that your planes are works of Art, and a small improvement in how the tote/plane meet would really push them over the top.
Now, we know that this may involve extra time and tooling, which both cost money in the end, and that you are cutting it close now. We appreciate those facts, and the facts that you've got bills to pay, so if it is un-economical for you do make some changes in this area we certainly understand. Just food for thought is all.
Still Friends?
Todd O.
Steve Knight
>Don�t worry all I feel no attacks and love to get this kind of feedback so I can make better tools. It�s what helped me all along.
First the problems with sliding dovetails are the dovetail would have to be the full length of the back. As the razee style eliminates rung the slot through the higher part of the plane. A mortise is the best choice though will a mortiser work in such woods? It is flexible enough to get around the different high�s and widths of the planes.
But getting the totes modified to fit is iffy. Hard to get these tote makers to change (G) Plus how to mount a tote so it is removable?
Countersinking the screw is a good idea but it would be hard to do as the tote covers the hole so you can�t use a drill.
Getting these totes on accurately is fun anyway. Getting two threaded inserts to match up with one at such a angle is pretty tricky. So using a dowel to locate the toe instead of the that screw is iffy to get it to match a hole. I would have to mount the tote then locate the hole for the dowel and drill it. Then glue a dowel into the tote.
I could put threads in the tote hole and use some threaded rod to hold it in place.
Part of it is the cost of getting another machine. I make anywhere from one to 7 razee style planes a week. But I usually eyeball the cutouts.
Getting the tote made differently is tricky too.
Steve, thank for allowing us...
Mike Schwing from Maryland
>...for helping you in the design process!
I really think, and yes this involves electricity, that the easiest, most reliable and accurate set up would be a jig to hold the plane body upside down and a template built that allows a router with a bearing to cut the exact profile of the tote, recessed/mortised 1/8-1/4" The template would restrain the movement, and depth control is easy as setting up a repeatable depth indicator/stop block.
Of course, conversely this could be done with the router in a fixed position and the jig/template above, using a handheld router. I'm thinking about production cost/time here, so I'm keeping hand chopping of a morstise out of my solution.
Thanks again.
Re: Steve, thank for allowing us...
Steve Knight
>I think the mortise could be cut with a handheld plunge router a self centering base and some way to make the router level with the highest part of the plane so the curve of the razee back does not get in the way.
That part would be the easy part getting someone to make the totes the way I need them is harder. Though the totes without the holes drilled would be easier to make.
Maybe go to a D handle shape.
Getting the totes made is one part then cutting the mortises is the other. I don�t think it would cost too much more really.
When I first started all of the feedback I got and all the comments when into my tools. I don�t change them as much now and I don�t get those comments. I think people think they don�t feel they have the right to comment. But hell I want that feedback so I can improve things. I am lost on the looks department so feedback is critical there.
I have thought about how to make my planes out of only two pieces of wood a sole and the body and mill out the interior. I think it may make a overall better plane for real long term stability. But the cost of the tooling to do it will be way over 3000.00 so it won�t happen soon.
Steve Knight
>I forgot I had thought about doing it by hand. But the mortises would have to be pretty good or the whole thing would look bad. Plus the wear and tear and time to keep a chisel sharp cutting the tropicals would be a real pain. Chopping a mortise in ipe or purpleheart or cocobolo or ebony would not be a easy thing to do.
What about a closed tote?
>For the razee style, a closed tote would give more strength and the front screw could be recessed in a hole and plugged or set just below flush. I'm thinking more of an infill style rear tote.
John
Re: What about a closed tote?
Steve Knight
>the D handle is an idea I have thought if. I just have to find someone to make them.
paul womack
>They are complex (i.e. slow i.e. expensive) to make.
If ya' wann'a make your own, here's all the information you need.
I suspect a "sanding bow" like the decoy carvers use might be useful when making such a handle - can any of the saw and/or infill makers comment?
BugBear
