Maintaining Traditional Oil Skins and �Tin� Cloth
Bob Smalser, Seabeck, WA
>Yeah, I know�nobody wears linseed/wax-impregnated cotton �oilskins� any more�they wear Goretex.
Well, that�s not entirely true. Those of us in the sawmill and lumber trade do, as do many loggers and heavy construction workers. Why? Muscling around hundred-pound planks of rough lumber wear through expensive Goretex in a matter of weeks�even the heavy-duty Carhartt or GI Goretex.
Wearing PVC raingear while doing heavy labor in the rain and mud merely postpones your soaking�work for long enough in it and you soak from the inside. Goretex and traditional oilskins both breathe enough to postpone that soaking much longer.
And while waxed cotton in lighter weights has always been popular in Britain, it�s largely gone gone over here. With the Yuppification of Eddie Bauer and L.L. Bean, who both used to manufacture their own distinctive gear, Filson of Seattle remains the only major manufacturer of this type of rugged work or expedition wear. And now Filson�s major market also seems to be suburbanites who want that distinctive �Northwest� look these days. Filson�s gear hasn�t changed since the Klondike Gold Rush, but the prices these days are Starbucks-high. But measuring cost per year of wear instead of merely purchase price still makes them the best value for some trades. The way to beat those prices these days is to buy seconds and used garments on Ebay.
Once a year these garments need their finishes renewed, and that�s what we�ll do today. But not with the 8-dollar, 2-ounce tins of oil and paraffin wax blend sold in stores�we�d go broke quick using those and will make a whole gallon of an even better finish today.
Three of several family garments above that need work today are readied. A hooded tin coat, a pair of old tin double-faced pants that look like leather�the �character� the garment has gained in use. Well, folks�salesmen may call it �character�, but it�s really a vintage blend of old sawdust, rotted forest duff and Shelton Gravelly Loam worked deep into wax and cloth as these garments can�t be washed. Next to them is a tin coat off of Ebay for the youngest son that had been machine washed by some misguided soul and will need a good bit of solution to renew. Prep is merely a stiff brush and a strong blast from a cold water hose to remove the bulk of the mud.
Shown above are a new, empty gallon paint can with lid and some of the materials we�ll use. A visit to Al Stedman the local beekeeper netted 5 pounds of beeswax at 4 dollars a pound. This is a much better choice than petroleum-based paraffin�just make sure you get the beekeeper wax and not waste your money on the 12-dollar a pound food-grade beeswax. Yours doesn�t have to be that clean...even if you do like to chew it�the natural impurities of the hive are probably good for you. You�ll also need a gallon of raw (never boiled) linseed, a can of pine tar, a can of turps, and I�m going to substitute some pure orange oil for some of the linseed to improve the aroma these garments bring to the home�especially after a bit of diesel fuel is slopped on them in minor refueling mishaps. Can�t find a can of pine tar anywhere? Your local farrier, large-animal Vet or farm supply will have it�it�s still used on horses� hooves as a dressing.
Rig a large double boiler�this one is a large pail of water stuffed in a kerosene space heater. I prefer to do this outdoors, both for safety (our mixture is flammable) and to test the consistency of my wax brew in the actual temperatures it will function in. Simply set your stir stick down for a while and check how hard your solution gets outdoors.
Into the can goes a quart of linseed, a little turps to thin, and two pounds of beeswax shavings after the water boils and the oil gets hot. The easiest way I know to render hard blocks of beeswax into shavings is on the shaving horse with drawknife�makes short work of it. It takes a while for the oil mixture to heat sufficiently to thoroughly melt all the wax, so be patient. When the wax melts, I add a half cup of pine tar and fill the gallon can about two inches from the top with more linseed�my orange oil fragrance enhancer going in last.
Proportions aren�t critical�more wax nets you better water resistance and greater garment wear�but also more stiffness. More linseed nets you the converse. The pine tar is there because I was raised in a traditional boat yard and wood boat builders add pine tar to everything. I believe it supples the hard wax some and gives it staying power.
Application is simple�brush it on hot direct from the double boiler and play a heat gun over it as you brush it deep into the cloth.
When complete, hang the coat up and go back over it with the heat gun to melt and smooth any remaining surface residue�.and you�re done.
Oh�and while you�re at it, do your work boots with the same brew�only much gentler with the heat, please.
Re: Maintaining Traditional Oil Skins and �Tin� Cloth
>That's a great article, Bob. Make sure you post it over on the Turning Forum. Those guys are much more likely than the average woodworker, and even those above average Neanderthal woodworkers who have a tendency towards hand tools, to get out in the weather (often at the tail end of a storm) to salvage the raw materials to feed their particular addiction.
A little explanation of "tin" in this context would be informational.
The color is right. Is this the same stuff as used to be worn by Downeast sailors, lighthouse keepers and lobstermen? The term "Macintosh" comes to mind? The �Northwest� look might just as easily be a "Downeast" look.
I assume you are preparing this one for publication. Would you prefer minor editorial comments were sent directly to you via e-mail instead of posted on the forum? What do others think? A "for example": In the second paragraph, "Muscling around...wear through..." should be "Muscling around...wears through...".
The following "outsidethebox" idea just popped up: How do you think Anchorseal might work for this application? Could it work to convert an initially non-weatherproof jacket into something durable?
...natural impurities of the hive... Do you mean Agent Orange? :^)
>Thanks. This article may be enough to convince me to get this type of weather gear -- I always wind up sopping when I work outside in the West Coast rain.
>Hate to say it, but I've never heard if Tin Cloth until now, so if nothing else this post has been educational in just that respect alone. Hopefully Filson won't stop carrying this material. Don't you just hate it when something good goes away?
The Yuppyfication of L.L.Bean-----shameful isn't it. :~(
Todd O.
LL is holding strong
Bob Hackett
>Just somthing to make you feel proud and start the morning right there Todder.
Seems the bean counters(hey,I made a funny)down at the headquarters in Freeport wanted to do away with that pesky lifetime satisfaction warranty thing.Something about the bottom line being improved.The old school told them to consider the warranty to be like Moses` tablets,absolutely sacred.Wouldn`t even consider eliminating it.Accountants-0,Customers-1.LL would be proud.
Mainely,Bob-Who drove right down and got SWMBO a pair of flannel lined jeans when he heard about it.
How to make a Flaming Torch
Todd Hughes
>I have been into 18th century reinacting for years and this method of waterproofing canvas is pretty popular.Mostly ground cloths, knapsacks, and some coats.Works ok but downside it is Extremly Flammable.A friend made some knapsacks out of canvas treated this way and for kicks we put a match to some scraps he had left over and it went up like it was soaked in gasoline which if you think about what you painted on it not to much difference probably.He actually uses scraps now as a firestarter! Have heard of more then a couple accidents where gear went up in flames.Personaly I would think if you use Raw linseed it would never dry, everyone that I have talked to that do this use boiled linseed oil with some jappan dryer mixed in. Many guys now just use Paint,[linseed oil, dryer and pigment] to waterproof canvas....
I have a couple oil skin garments, a English Barbor hunting coat,another "Out Back" one and a really nice mid lentgh Duster that a girlfriend had custom made for me from some outfit in Montana.I bought a can of wax treatment in a store that sells Australian items and clothing a few years ago and after re doing my coats once a year still have about half a can left.Believe I paid $12 for the can.....Think it was money well spent.....Todd
Re: How to make a Flaming Torch
Pam Niedermayer - Austin, TX
>I've always wondered about those white tents seen in civil war photos, whether that was a function of the film (orthochromatic) used or if canvas just used to be white. Maybe they were painted?
Pam
