Tuned my Ulmia mitre saw
Christian Aufreiter, Austria
>Hi folks,
I really love my Ulmia 352 mitre saw because it gives my the ability to make precise square and perfect mitre cuts. But I've never been very happy with the smoothness of the cuts, I noticed some tearout, especially when cutting small battens. In order to improve this situation I decided to buy a Japanese blade for a framesaw http://www.fine-tools.com/gestell.htm This blade was 600 mm but my Ulmia needed a 550 mm blade. So I cut and filed the blade and drilled the holes which hold the blade later. I can tell you that this was a real pain. The steel is extremely hard and my hobby shop is not equipped with this kind of drill bits which make such a job easy. Anyway, I got it done and couldn't be more enthused about the smoothness of the cuts. A Japanese blade means a major improvement to the classic Ulmia mitre saw and I can only recommend to try this setup. I'd call this a perfect symbiosis between Japanese and European tools.
Regards,
Christian
