200+ woodworking book reviews
PC 890 fixed base router problem
I have a PC 890 series router with a fixed base. � The base in question has the vacuum “port”. � The router slowly slips while I am using it. � I don’t have the problem with the other fixed base (which I use for dovetail work). � Any suggestions?
Re: PC 890 fixed base router problem
I looked at my PC 890 with fixed base 8901 Type 2.  If I open the locking handle fully, there is a hole through the locking handle that lines up with a torx (?) screw.  I am guessing if you tighten that screw it will squeeze tighter.  I would start with a quarter turn and sneak up on it.  Looked it up on E-replacement parts and that screw appears to come coated with LockTite to keep it from vibrating out of position.  If yours is not Identical I bet it's similar.
Thanks
