Watco application help in hot weather
I live in the Palm Springs area where temps cool down to 70 and highs in 100. I start doing anything from 7-12 am. I was going to use Watco on tool handles but now after 15 minutes it turns tacky. When this has happened I take a cheesecloth with oil and apply it but remove it right away. I imagine the finish is very thin,so I am reaching out to the finishing experts.
I used a thinned spar varnish for one coat, roughed up with 180 then applied a second coat scuffed with gray scotchbrite. The thinned varnish worked fine and after 3 weeks the varnish turned into a gummy mess. Even after using drain holes inthe can body, the varnish turned bad. At $25 a quart I can't be buying varnish every other month. How do you eliminate the air in the can ? Will a shot of MAPP gas work ?
Cheers
