For Peter
For Peter
For Peter
Peter,
I know this is probably the wrong place for this, but for the life of me I could not find a place to post this.� My apologies in advance. On my post below to Barry what are all the question marks in the diamonds?� I wrote Barry's post in Word and did a copy and paste.
Thanks
Mike in Zuni VA
Re: For Peter
Re: For Peter
You are not doing anything wrong. It's called the Unicode REPLACEMENT CHARACTER used to replace an incoming character whose value is unknown or unrepresentable in Unicode. From your description, I suspect Word is embedding something that the forum editor is unable to translate and it is using the replacement character.
You might try pasting as plain text. There may be an option to do that when right-clicking to display the paste menu option, or use Ctrl+Shift+V instead of Ctrl+V.
If you used a password when posting, you can use that password to edit your post and attempt to remove them. We can also edit posts from the admin side to clean them up, which I sometimes do if I notice them.
I've tried writing code to search for and remove these these replacement codes but have not been able to make it work. Thanks for reminding me of this issue, as this has been an ongoing issue I want to fix.
Re: For Peter
Re: For Peter
Re: For Peter
Jim DeLaney, Austintown, Ohio
Re: For Peter
Could it be that the symbols are replacing one of the double spaces some folks put between sentences?
Re: For Peter
Re: For Peter
Possibly, but in this case I think it is Word (Mike says he is copying it from Word) is using a code for a paragraph break that the forum code isn't translating into the HTML code for a paragraph break. In this case, it is being translated into U+00C2 which is the Latin capital letter A with circumflex which the forum does not understand and replaces with a Unicode replacement character.
Why are things so complicated? Arrrgh!
Re: For Peter
Re: For Peter
The following regex in the Perl scripts seems to fix this issue
s/\x{00C2}/<p>/g
but it renders the toolbar option to insert special characters unusable so I disabled it. How the above code would effect that dumbfounds me, but it somehow does.  Always sumthin'. :(
