Anybody know about drying wood?
I had a sweetgum tree that was a nuisance at my rental house and I had it cut down and logs sawed into lumber.  A couple of 9/4 slabs out of the center of the butt log and the rest is 4/4.  Stacked and stickered it in my green house that I am trying to use as a kiln .  About 600bf.
The question is, can I pile dry lumber on top of the pile?  Will that wood remain dry or will it absorb moisture from the green stuff?
Re: Anybody know about drying wood?
The humidity must be really high during the day. That will raise the moisture content of the dry wood. Make sure you treat the fresh cut wood with a preventative pesticide. I hope you are circulating air in the greenhouse
Thanks Dick
I have a fan in there and will probably add another.  Figuring out a timer to turn the fan on and off.  I have some Bora Care and wish I had sprayed it,  may see what I can do now.
Dried a load of red oak in the same set up last year and it seems to have done well.
The green house was not designed for this and is very awkward to load and unload.
Re: Thanks Dick
Are you circulating the air out of the greenhouse as well? The more moisture in the air, the less drying you will get.
Also, a sheet of something over the greenhouse or stack will prevent the top of the stack from drying too fast in the sun. The top surface will get pretty hot in direct sunlight.
Don't forget lots of mouse traps around the pile. Stickered wood is luxury housing for mice. If they pee on it enough it will stink.
Mixing dry material with green stuff is not ideal because the dry material will absorb some moisture from the wet stuff. Just how much is debateable and, given time I suppose, all the material will come out at about the same moisture content.
One key to drying from green to about 20% MC is airflow to take moist air out and away from the wood, and out of the shed/greenhouse/building and drawing replacement air in. You mentioned rigging up a fan. If you are using a fan airflow should really be alternated on a regular basis to equalise drying throughout the pile, so perhaps change the airflow direction every 12 or 24 hours if your means to change direction is to simply pick up and turn the fan(s) around. Airflow in just one direction throughout the drying process results in the material at the upwind side ending up drier than the wood at the downwind side, and possibly a leaning pile. A steady airflow of about walking pace (~3 - 4 mph) is often cited as about right.
Further drying to below 20% MC means that airflow importance diminishes significantly because the main driver from that point downwards is relative humidity.
You've essentially got yourself a crude solar kiln in utilising a greenhouse so it might be a good idea to read up a bit on the ins and outs of solar kilning if you haven't already done so. I think I know of one or two decent sources of information on wood drying or seasoning, but I'll let you do the research on that topic, ha, ha. Slainte.
If you want the dry wood to stay dry,
You should wrap it in plastic which will keep the moist air from getting to your dry lumber.
Re: If you want the dry wood to stay dry,
I disagree.
All air has moisture in it and the warmer the air, the more water it can hold. That is can, not will.
If the wood is wrapped with plastic capable of keeping moisture out, it will hold whatever moisture is in the air and wood inside as well. When the temperature goes down at night (we have a frost warning in CT this week) the water vapor will condense. You end up with a cycle of evaporation and condensation that will be a good place for mold.
I had a pallet of cedar shingles left from a house project. I had them covered with a tarp for eventual use in a shed. Rain and snow melt were able to get under the bottom of the tarp and soaked all the boxes even at the top. I did have a lumber pile drying with a loose tarp and the air could circulate without holding moisture inside.
Controlling where and when water vapor condenses is a major issue with any air treatment. It's impossible to trap it without bad consequences.
Steve, I don't have a Phd in front of my name for drying wood, but this guy does, and the last two paragraphs is what I was saying.
https://www.woodworkingnetwork.com/knowledge-center/wood-dr/moisture-change-stored-lumber
That plastic at the end of the article seems more applicable to commercial shipping than home storage. It also states the wood is dry when the plastic goes on and the OP was a question about getting the wood dry.
I've seen a lot of damage when water vapor gets into an impermeable space and rots the wood. Sealing off the bottom of a dry stack so that humidity stays out sounds difficult to me.
Steve, Barry ask about stacking dry
Lumber on top of green stickered lumber. All he needed to do is spread the plastic on top of that stack, then dead stack the dry lumber on the plastic then wrap it on up. And if Barry is as frugal as we all know he is by now, he can get the tough wrapping material that the wholesalers use by pulling it out of a dumpster at almost any lumber yard for free.
Once the lumber is dry and in the wrapped up bundle, any moisture at around or below 12% MC would be bound in the wood, and not likely to condense inside the packaging.
More thoughts...thanks...
The green house was built to add solar heat to my house.   Many years ago.  It's like a lean to and the door is in the end.  So I had to load the lumber from the end.  The stack is about four feet wide and nine fee long.  I tried to leave spaces between the boards and have a fan on the near end sucking air thro0guh the stack.  I would put a fan on the far end but I have to climb up the end and crawl over the top in limited space and drop the fan in.  Not as much fun as when I was younger.  Right now I just turn the fan on and off manually.  Thinking about some sort of timer or controller but at that rate I think these days the stack will be dry or rotted before I figure it out.
Should the fans be blowing sideways or lengthwise?  I am thinking very gentle air flow would be best.
The Red Oak I pulled out of there had some very light green mold on some of the sap wood. Been in there a year with no fans.
The air can rise vertically and go out of vents on the second floor and the fan is blowing gently toward the door on the first floor.  I am also thinking the fans should be in use long enough to reduce the surface moisture below the level that would support mold.  I hope that coincides with the time it takes for me to lose interest and stop fiddling with the fans.
Pictures would be helpful!
Re: More thoughts...thanks...
I'm guessing you didn't read my message, Barry, or maybe didn't see it.
I mentioned speed of airflow there - 3 - 4 mph is considered a good rate. A crossflow is better than end to end, but if you can't achieve that just do the best you can with a lengthways flow. Reverse the fan on a regular basis to help prevent irregular drying of the stack. The fan can push air out of the high set vents as well draw air down from them.
Getting the wood down below 20% MC will go a long way to preventing mould development. As I said before, air movement plays the biggest role in getting moisture content down from green to ~20% MC. After that, the main driver for further reduction of wood MC is relative humidity, although some air movement is good. Slainte.
Barry,
Why don’t you use resources that you have right here in VA? I have included links to some Va Tech sites
which has an excellent forestry program. The second and third link deals with building and operating a
home solar kiln. Just guessing, but I think smaller than yours. The fourth link is to an associate professor
(again I am guessing) that also acts as a extension agent for forestry and related industries. Might be able to
get some authoritative answers.
Mike in Zuni VA
https://sbio.vt.edu/for-the-community/wood-drying.html
https://www.pubs.ext.vt.edu/420/420-030/420-030.html
https://vtechworks.lib.vt.edu/bitstream/handle/10919/98866/420-030_pdf.pdf
https://wood-products.extension.org/brian-bond-virginia-tech/
Pointing a fan at the end grain will increase the likelihood of end grain cracking.
I believe that a dehumidifier will be a big help in reducing the drying time.
One of the major advantages of solar kilns is the soft cycling at night. The surface dries pretty hard during the high temps of the day, but then the humidity and low temperature of the night softens the surface at night. You get very mellow wood out of a solar kiln. I would suspect that a dehumidifier would stop that cycling, making the load dry faster but with more danger of case hardening.
