California Air Tools compressor questions
I have a California Air Tools compressor, 30 Gallons, and I have it on a timer so I can run it an hour or two here and there. Yesterday I noticed that it continues to do the little "spit" thing after the power is off, in effect draining the tank completely over time. (For those who don't know, it spits out a little air every thirty seconds or so to drain the tank of any moisture.) I sent a message to the company telling them I found this irritating and a waste. Part of the problem is I had a much smaller compressor before and left it on continuously for about thirty years so air was available. With this one I decided to add the timer because it finally occurred to me it could blow off a fitting or spring a leak and run forever which would naturally occur while I was away. I asked if there was a way to reset this feature so I could store and use the remaining air in the tank. It takes the unit about five (long) minutes to come up to pressure and that's a long wait to drive a few fasteners. The company sent back and said I should do maintenance on the unloader valve. That it could be bad to leave a tank full of air for a long period. Have I made it clear I hate change and new fangled stuff? I think what I need is a much smaller compressor that would pump up faster. Any thoughts?
