Weekend
So the "internal" vacuum fittings on my Stubby refused to make a good seal since I moved the lathe out to the new shop. Short of taking the headstock apart, I just couldn't get the rig to hold decent vacuum, so out came the old "E-Z Vacuum" fittings, and built new piping incorporating the filters.
Bit of a pain that I have to insert the tube through the spindle each time, but it pulls 26" of vacuum so I'll make do.
I've had a large (20+") Ambrosia Bowl sitting on my shop desk because I didn't like the original flat rim treatment
With the vacuum working, I mounted the beast, switched on the pump, and redid the rim to roll it from a sharp outside edge to a curve that blends into the inside surface.
Pleased how the change lightened up the visual weight of the bowl more in keeping with my design principals.
I don't usually put finished stuff back on the lathe, but this rim was really bugging me.
