Power and hand together (2): we have cases!
The target was to create mitred panels for two cases, which would form the basis for two night stands ...
And then they needed to me rebated at the rear ...
Finishing up with all these ...
Time to tape together ...
And glue up ..
We ended here ..
Today I made a template for the bow fronts, marked the curves , and used the bandsaw to remove most of the waste ...
I contemplated cleaning this up with spokeshaves, then came to my senses and used a trim router and flush trim bearing ...
And cleaned up with a HNT Gordon spokeshave ...
All the trouble at the start to make the mitres as clean and tight as possible. How did we do?
The rebates and mitres look good ...
And I like the bow fronts ...
Tight mitres too :)
Re: Power and hand together (2): we have cases!
Derek, looks great!
What are the windows for?
Andy
To look outside? :)
They will house drawers. More going on inside the case than outside.
Beautiful work
I'd say the miters and the grain matching came out mighty well, Derek. Is that clear plastic packing tape you used to clamp the miters when gluing?
Re: Beautiful work
Thanks Ellis.
Yes. It can be pulled tight/flat and has less stretch than masking tape. Plus is waterproof, which means that glue does not leak out onto a bench top.
Here is a close up ...
The whitish "mark" in the centre of the board is the reflection of a light on the shiny plastic.
Good tip
As long as the adhesive doesn't pull out too many surface fibers, this is a fine way to do it. Thanks for sharing.
I don't have a mitre shooting board and don't have time to build one before these boxes for my cousins' ashes have to be completed. I improvised with an oversized, angled sanding block. Took some elbow grease, but worked fine.
Just glued the top on this afternoon (and remembered to put the ashes inside first). Now to sand, round over corners, and put on some finish.
