Taekwondo Fixture Plan?
I'm looking for plans for the wall-mounted "rebreakable" board holder so my grandsons can practice at home.  Their instructor will not (strangely) allow me into the dojo area to take measurements on the units he has on his wall.
Tia
Re: Taekwondo Fixture Plan?
This is what it looks like, but the board holder is the problem to be both adjustable (as the kids grow) yet hold the board so that they are still breakable.
Joe Fleming
Are you spying through the window?  :)
Actually
No.  Just paying for the whole tuition.  :D
For the one in the pic, the "board holder" is the cords. The bottom adjustable piece has the add-on broad for the breaking board to rest on, t=but the top adjustable piece is positioned so that the top of the horizontal goes against the top of the board to be broken and the cords hold it there. Hopefully, they hold the board tight against the horizontal boards. That is probably better if the practice is with the plastic re-breakable boards. If actual wooden boards are used, it might be better if the top holder is a mirror of the lower holder. The difference is that the back surface of the wood does not normally get taller when it breaks, but mechanism for the plastic re-breakable boards do make them get larger as they come apart. The construction is a T-track screwed to (probably) a sheet of plywood and then 2 pieces of plywood are attached that are slightly thicker than the T-track. You do not want the T-track to be proud. Things would work more easily if you used 2 T-track attachments for the lower shoe to keep it level. The cover for the electrical outlet give you the ruler for measuring the fixture.
