Bandsaw resaw blade question for Eliot and anybody who resaws...
Eliot,  I recall you have a Laguna Resaw King 1" wide and you like it...Right?
I have a Laguna SUV 3hp BS with 14" wheels I bought for the sole purpose of using it as a resaw.  (I have another bandsaw I use for general purpose bandsaw stuff.)  My plan was to leave an excellent long lasting resaw blade on this bandsaw so I could just walk to it and resaw something when the need arose.  AS many of you know I bought a 1/2" Laguna Resaw King Blade at the direction of Laguna Tech support with the assurance that the reports of the blades breaking was an early adopter problem that had been solved.  The one I bought for $174 lasted a matter of seconds.   They wanted me to accept another one and I said No, send me a 1" one.  They would not, so I made them send my money back.  So now I need an excellent resaw blade.  What would should I buy?
Re: Bandsaw resaw blade question for Eliot and anybody who resaws...
Jim DeLaney, Austintown, Ohio
Try the Lenox TriMaster.
Unlike you, I am not a cheapskate, but I would rather slide neked on 60 grit and land in a tub of iodine than pay more than 20 bucks for a bandsaw blade.
Olson.
https://www.olsonsaw.net/cat/band-saw-blades/
I resemble that remark...
Actually, I think of myself as more like frugal.
The problem is I hate fiddling with bandsaws and tuning them up to run correctly.  My tablesaw suits me better.  With a excellent blade on it I can just saw stuff.  No tweaking the alignment every time I use it or even when I change the blade. A couple of minutes and I am working again. The bandsaw, not so much, seems like half and hour or more.  Change the blade and it's time to leave the shop.
I do love taking nothing and making something out of it.
Barry, I use a Lenox Tri-Master 1" x 2/3 variable-pitch blade on my 20" bandsaw. I am not sure whether Laguna recommends using a blade of this width on their 14" saws; I imagine they would allow it, possibly with caveats. I know I wouldn't think of using one on a 14" Delta or Taiwanese/Chinese knockoff bandsaw because of the tension required and the structural strength of the saw frame, not to mention that the relatively small wheel diameter puts a lot of strain on a band this size, which can lead to band/weld breakage.
I'm  no expert on band saws or band saw blades. What I can say with  confidence is that on my Laguna HD 16 the one inch Resaw King carbide blade is a near perfect blade for nearly everything you want to cut straight, i.e no curves to speak of. I leave it on mostly for resawing, just the way you want to do, and it's just terrific. The cut quality is very fine. I paid about what you paid for it. No trouble whatsoever.
But don't forget ( I think I've said it before) my wheels are 16 in diameter,and yours, you say, are 14 inch, and that could cause too much flexing for this kind of blade when it is running. Probably not -- but worth asking about.
I also have the 1" Resaw King blade on my Laguna 16.  Flawless cuts for veneers.  I've had my saw for about 20 years and am only on my second blade.  Laguna only recommends the ¾" blade for the 14" saws, though.  A ¾" Lenox Tri-Master would be an alternative.
I have a 14" Delta with a riser. Using highly rated blades such as timber wolf or olsen gave me unsatisfactory results. I was in the process of seeking out a bi-metal Starrett blade and came across a Starrett Duratec from Woodcraft in my shop. That blade works great and I am able to take full depth cuts in hardwood despite the small motor on the saw. I believe I have the 3/8 model - the saw can't tension really wide blades.
For me, the Starrett was a game changer and somehow much better than the other blades I've used. You can try the Duratec for $20 and upgrade if you like it.
https://www.woodcraft.com/products/starrett-duratec-sfb-bandsaw-blade-82-x-3-8-x-4tpi-skip
So has there been a resolution? What did Laguna finally do about it all?
So has there been a resolution?Did  Laguna come around?
Lenox does make some Tri Master blades that are .025" thick rather than the more typical .032" (or more) resaw blades. That's the same band thickness as common carbon steel bandsaw blades so I'd think they'd be less prone to breaking. Looking at Spectrum Supply's web site, it looks like the Tri Master 1/2" X 3 TPI is the only .025" blade listed.
