Ides of March one day late
Alan Young
A Day late but perhaps if Julius Caesar had one more day things would have turned out better for him.? I've taken the liberty of posting the Ides of March question.
My question is: What tool have you found a new use for outside of its assumed designated role? My answer is the wood chisel. And its use is basically as a cabinet scraper. I have cabinet scrapers and do use them for their designated purpose. I don't seem to be able to roll and burnish the burr on the scraper. I'm sure like anything else if I would practice more I'd get better at it. I have found however that a well sharpened chisel works beautifully as a cabinet scraper. I chose various width chisels and keep them for this purpose. I also tenderly round the corners on the sharpened chisels so that as I drag the tool across the wood surface the corner of the chisel would not create a gouge. There is of course a technique that needs to be carefully administered using the chisel as a scraper-most specifically the need to avoid creating an uneven surface from one long scrape to the next. I have found that the handle of the chisel gives me very good control over the angle and force with which I apply the scraping technique. This technique for this tool is particularly usefull when used to remove an old or bad finish-rather than chemically stripping or using a sander....So without further reasoning behind my use of the chisel as a scraper-there is my Ides of March question for you all albeit a day late. What tool have you found a new use for outside of its assumed designated role?
Re: Ides of March one day late
I have an old 1" Pexto bench chisel that has seen considerable duty in the last couple weeks for chipping stubborn tile mastic off plaster walls and remnants of self stick tile from the hardboard floor of a bathroom. Nothing else has compared in effectiveness.
Rounding the corners brings back memories for me. My grandfather was a house painter. One day he was in my shop and saw my scraper. I had rounded the corners. He was very upset. He clearly stated that the corners must be sharp so that they will be effective in digging out any soft/damaged spots that will have to be refilled.
I use my sit on riding mower to pull out dead bushes.
Ad hoc work benches
If I have a work bench it is always supporting piles of stuff. So I use wood retaining walls, decks and saw tables to support work. Always cry about the loss but have survived 40 years without.
It's actually the card scraper that you don't use. I use it to extend the kerf when cutting half blind dovetails. Works perfectly.
I used to have a farmall cub to pull things.  Now I use my engine crane.
As a general rule when one can't get something sharp one didn't  lay a sufficient foundation.  I have known this for 40 years or more, yet I still get snagged by it.  I have been easing into scything, and yup.  Couldn't get it to cut, and when I did, it was because I hadn't built the proper foundation.  With card scrapers, I hold them perp to a belt sander, then roll the edge.  It may not be ideal, but it only takes a second, and the results are still excellent.  Some of the methods involve precision jigs, and lots of different stones.  If they cut or last better at all, it is barely noticeable.
And there are scraping chisels, usually the bevel is like 85 degrees.
A classic is using a chisel to roll the edge on a scraper, though I have the real thing, and I would usually use it.
Re: Vac bagging with the shop vac...
works a charm with flat or flexible materials.  I have done jobs with up to about 100 square feet, though there is no max, if there are no leak.  I have done stacks of ply 20 layers thick, also.  Usually needs to be epoxy glue.
I use a t-shirt press to glue small flat things fast, with controlled heat.
Of course, using something to do something it wasn't designed to do, is no big deal compared to inventing tools from scratch...
I use a hockey puck when I need a little les persuasion than offered by the rubber mallet. I use a burr-less scraper to trim the nubs off the final coat of finish instead of the recommended brown paper bag denubber. I use the non-fluted section of a high speed steel drill bit as a burnisher for scraper sharpening. I use my radial arm saw as a drum sander: attach a drill chuck, add a spindled drum sander and rotate the saw to the desired sanding angle in relation to the saw table. I use a fired 16-gauge shot shell as a planing stop on my work bench.
