Question on stabilizing wood in a pressure pot?
I just looked at an estate sale and there is a pressure cooker there. Could that be used as a pressure pot to stabilize wood? How much pressure is required? Which is better vacuum or pressure?
Re: Question on stabilizing wood in a pressure pot?
Stabilizing requires as hard of vacuum that you can get. Casting uses pressure to reduce bubble size.
The gasket on a pressure cooker is made to expand tighter as the pressure builds inside, so I’m doubtful it would hold against much vacuum.
Pressure alone without pulling a vacuum first would only compress the air within the wood, which would then likely be carrying the fluids out as it expanded when the pressure is released.
Rather than trying to sink your blank in a large dish of whatever fluid you choose, I think what I would try, would be to contain your blank in some sort of bag buried in sand inside your chamber, with a tube running into the bag. After the vacuum has been drawn a while, rather than dropping the vacuum by keep it clean letting air in, the tube could then slowly draw the fluid into the bag, and then be absorbed, or drawn into your wood as the pressure comes up in the chamber through the supply line going right to the wood first.
I’ve not done this, but this is how I contemplated it when I thought I might.
Did you follow what i was suggesting?
I have done some test, where I submerged a little block of dry wood under water, within a quart jar hooked to vacuum pump. While drawing the vacuum, I could see tiny bubbles fizzing out. I’m not sure if all those tiny bubbles would burst if they were in a viscous sticky fluid like epoxy. But by letting it in after the vacuum is already maxed out, seems like an easy solution.
I believe they build racing sailboat hulls by laying dry glass or carbon fiber cloth right on the gel coat, then covering it with a vacuum bag. After pulling the vacuum, they open little ports around the edges that allow the epoxy to be drawn in. It will then only fill the space between the fibers, with no chance of over filling, making a lighter stronger hull than wetting by hand.
I made a crude vacuum chamber years ago by just cutting the top off of a well tank like millions of farms use. I tried finding some off the shelf gasket to use, but couldn’t, finally just running duct tape around the seam, and that worked fine. There were already plumbing threads on the bottom, and a little air stem on top for the bladder.
Oh, you could test your pressure cooker by simply shoving a hose over the stem where the weight sits to test drive the gasket.
Re: Did you follow what i was suggesting?
Your description of how they do the boat hulls seems to be the favorite way, evacuate, then let in the liquid. I have read that for tight-grained woods they will then add more liquid to the surface and apply pressure to aid in driving it into the less porous grain. They also don't seem to use quick-curing resins and take it very slowly.
Seems like a great project for somebody who likes to experiment!
Bill
My typical use case is a tool or knife handle so that has informed my chamber design. YMMV. I used 4" abs pipe and fittings to create a vacuum chamber. I drilled and tapped a hole for 1/4" npt and fitted a male air fitting. I arranged vinyl tubing for my vacuum pump that is a snug fit over the air fitting.
In use I will take a new heavy (freezer grade) ziplock baggie sized for my object. If there is a lot of extra room in the bag I'll bundle it around the object with loose ties. Arrange the thing in the bag, pour in enough resin to submerge the wood part, squeeze out most of the air and seal up the bag. Put this in the chamber and seal the chamber. Apply as hard a vacuum as your pump will and hold it until the bubbles stop coming out or overnight if like mine your chamber does not have a window. Then release the vacuum and apply a bit of pressure. 20 lbs is what I usually set the regulator to. Leave that for a couple of hours. Release pressure, pull the part out of the chamber, wipe it down and leave it in a warm dry place for a while to cure.
I saw a Making a pressuru some where on the internet
