A55 Smoothing Plane
How to cut sandpaper question??
A friend gave me fiftyish Norton sticky back 12" sanding disks.  The problem is my sander takes 10" disks and these are 12".  Is there a simple way to cut them down?  I am thinking some sort of compass with a razor knife blade?
(I don't need them all, at my age ten is probably a lifetime supply.)
Re: How to cut sandpaper question??
My thought would be to stick one to your 10" plate then cut to the size of the plate using a utility knife as you slowly spin the plate.
What grit are they? Something like 120 will be pretty easy to cut. 80 grit will be like cutting pea gravel. Trammel point system with an X-acto blade would be the way I would cut them. And cut from the back side. An old tin snips would be my second choice. I might be interested in some of them. Not perfect for my 20" sander, but better pricing.
The box says they are 60 grit.  Metalite R228.
Or if the plate comes off/goes on easily, lay it on the disk and trim around it with the utility knife on the non-grit side. Utility knife blades are easily replaceable.
Bill
Barry, If you only need ten for your lifetime, why not just use a pencil and one of your 10" disks for a pattern to mark on the backside of the 12 ' disks and trim with an old pair of scissors.
Use a compass. Tape an exacto knife to the pencil and you should be all set.
