Something to Grow On
Daughter asked if I could help her convert a wall into a place to put her plants; some succulents, others stuff needing more or less light, some short, others tall.
Result is
Framing is 1 1/2" black birch with "shelves" in 1/4" thick walnut slats and shelf supports glued/pinned into dadoes.
Wall space is 7' so the shop-build had to be in two sections joined with steel pins.  Not seen is a piece of Visqueen under the base to catch any water drips and protect the wood floor (I hope ;) ).
Re: Something to Grow On
Nice Mark, I’ll bet she and the plants are going to like that.
Thanks, Keith
Didn't take her long to fill it up.
Waiting the "could you do another" request :)
Is this a mockup for Svante's sideboard mentioned below?
Nice plant stand.  Hope my son does not see it.
I have never seen anything 100% effective at controlling water around a plant stand. I hope the edges of your sheet of plastic has the edges turned up somehow. Personally I would have made the base a tray with a good coat of epoxy on the inside.
Considered That
But the unit is in 2 pieces.  I figured a drip pan would get too hard to clean to prevent mold growth so the plastic sheet can be pulled out from the end and cleaned or replaced without taking the whole thing apart.  As all the pots are on plates, drips and spills are minimized.
Re:Moisture will still be a problem
The plastic will block natural ventilation through the floor and cause mold. Basement floors are especially prone. You could make concrete basins with standoffs. As long as the moisture protection has air space for ventilation.
Another issue will be insect pests. They gravitate to the planter soil, even plants. I studied indoor green walls for my profession and they never mentioned bugs getting sucked into your mouth. Every pot I had for 60 years had residents other than plant kingdom.
Wood Floor
is new so $12g "renovation" is not getting used for drainage.  The ends and cross pieces allow air the circulate up through the slats, so any drips evaporate quickly.  Bugs are everywhere, of course, but her potting media are baked before use, and plants are inspected often.  Fauna colonies are removed for processing and repotting in clean media.
