Building the bridges-post installation
Installing posts
We begin with a bridge that has been decked with curbs.
We found the decks are not straight as a result of variance in the height of the ties beneath and variance in the trestles that support the stringers. A top rail that undulates looks bad. To get the top rail straight each post must be custom cut to length so the tops line up, with the length determined as follows.
Posts are permanently secured at each end of the bridge at the target height. A line is then tightly stretched between end posts. Measurements from the tie tops to the line reveal the height of the post at this position that will result in a straight top rail.
In our case we simply cut a 4 x 6 x 8’ in half to yield approximately two 4’ posts with the top angle of the post 12 degrees. The “approximately in half” is easier said than done. These end posts must be of a height that the sum of the posts that fill in between the ends work out to not have waste from cutting 8’ post timbers approximately in half. For example, if the bridge sags in the middle the end posts must be cut some less than 4’. The first post might be 47” yielding the second post from this 8 footer 49” to be placed where the bridge sags. With a bit of measuring and calculation it can be worked out that cutting the posts shorter than 4’ yield all the posts required that are longer than 4’…..for the most part. We had one bundle of 4 x 6 x 8’ that was in fact 8' ¾'’ and this pack saved the day on the long bridge that undulated 1 ½” in height relative to true horizontal.
So, we have our end posts set and of optimum height. We measure from the top of the tie to our string and write down the length. A table of posts is generated, for example, post #2 47 ¼, post #3 47 3/8, etc. A chop saw is set up, 4 x6’s hoisted up to the saw and the posts cut and numbered. Numbered posts are loaded onto a cart for transport across the deck to the location they are to be installed.
As they are loaded onto the cart the pilot hole for the 6” Power lag which fastens the post to the curb from the back side is drilled. A template locates this hole and they take but seconds to drill.
Next fastening hardware is distributed down the bridge at each post location. The 6” Power lag is started into the back side of the posts.
Now comes the key part. A tape measure is stretched down the curb to provide a running distance from the start post. Using this tape measurement as a guide the angle bracket is screwed to the curb with 2- 8” Powerlags. The edge of the angle bracket is located such that when the post is secured to the angle bracket the centers of the posts will be exactly! on 4’ centers.
Posts are trivial to install with two people. One person sets the post on the tie and the second drives in the 6” Powerlag from the back side of the post with a battery powered driver. It is critical that the post edge align with the edge of the angle bracket to yield posts whose centers are exactly on 12’ centers. The through bolt is not installed at this time, nor is it important to plumb the post at this time. It takes on the average only three minutes to install a post.
With the center of every post spaced exactly at 4’ the rails can be cut exactly at 12’. All the rails for the bridge except the ending rails are cut, loaded on the cart and dragged across the bridge for installation.
Re: Building the bridges-post installation
Wiley Horne
Really a compact efficient procedure. The taut string and setting the angle plates right on 4’ centers eliminates a huge amount of fiddling around when time comes to set the posts and later place the 12-foot rail pieces.
Do I understand right—at the outset, you make up a master list of post heights, so you can find a place right off the chop saw for every shorter end (say 47-0”), simply by referring to the master list—oh yes, this will be post 96, write 96 on it and done!
Wonderful time and motion on the lion’s share of your cost!
Wiley
Us workers of expensive hard woods get very good at making cuttings that don't yield scrap. I have not seen this trait in carpenters. Grab a piece of 12' and cut 3' off it. We ordered a pack of 10' to deck the observation area. Had 36 pc left from the 80 pc pack. And we had 8' deck boards. All the odd lengths of rail for the end of the rail runs came out of these lengths with piddly waste. After 3 bridges I utilized every one of the 10' pieces to good advantage. Were I not on the job they would have been cut from 12' rail lumber because, well, it was "rail lumber".
All the cut-offs I stored in an organized way. If a short piece was needed I checked the pile to see if could be found there. Rails ended with some 4' lengths. These all came from the cut-of pile.
It is better than you imagined. We had 3 bridges going. The big one had the most undulations due to variable ties and worse, we discovered the i-beam flanges were built up in 1/2 increments as one got closer to the center of the span resulting in a 1 1/2" rise that repeated 3 times for 3 spans. I moved post cut offs between three bridges for optimum utilization of lengths. In the end we would up with 4 short posts and I am saving them for a tiny bridge #10 that we will put a 42" rail on. I amazed the carpenters, who I can not say enough good about.
I embedded myself into the construction crew, enabled by the cost plus contract. When I saw an opportunity to save, I suggested the change. If the suggestion had merit the change was embraced without resistance. Perhaps these suggestions were considered because I become their problem solver. If they had a problem I took care of it,.......and kept them in cookies and brownies. I sharpened the big drill bits, quickly dulled by drilling ties. I sent chop saw blades to Misenheimer to be sharpened for $12 instead of buying a new blade. etc.
