Red Oak questions Insects and drying checks?
A little over two years ago I had a huge red oak cut into slabs about 3" thick on a Lucas Mill.
They were stickered and stored in an open warehouse sized shed. They were painted on the ends with latex paint and sprayed with BoraCare.
Pulled out a couple and had one of the smaller ones flattened on a CNC. It's about 38" wide on one end and 28" on the other. Making a computer desk for my son.
Also cut the end off one about 38" wide to make legs. Cut off 32" and then ripped it into leg stock. Cut the other end back to 30". that's when I started to notice trouble. Cutting the painted end off revealed checking. The painted end looks good. The surface looked good. One or two minor checks after stock prep. The first cross cut 32" from the end looks nearly perfect. The checks from cutting the end off are at least a 1/16" by maybe 1" and there are three or four in almost every piece. So, is this characteristic of red oak?
The other problem is that I have found two different insects. In the 32" piece I cut off there are some worms in a patch near the end with the paint. Did I miss a spot with the BoraCare? And on the piece that was flattened with the CNC I just spotted a cluster of really tiny holes, about five over an area the size of the palm of you hand. The worms make a hole about 1/16" in diameter. These holes are a 1/32" or less. Anybody know what either or both of these are? And should I spray with BoraCare again? (I have 35 more slabs)
