Speaking of Alcohol *LINK*
Mark Mandell - Gone Round in New Jersey
Straight Ethanol is being sold as a bio-fuel.
See the link.
I'd like to know if anyone here has used the stuff for shellac? I'd really like to dump the methanol and other poisons they use to "denature" ethanol. I read that they get this stuff by the ATF boys and the Revenoooahs by putting a bittering agent in it so nobody will drink the stuff.
TIA
Hooch?
Re: Speaking of Alcohol *LINK*
>>>...I read that they get this stuff by the ATF boys and the Revenoooahs by putting a bittering agent in it so nobody will drink the stuff.
That's precisely a common definition of denatured alcohol: ethanol with a bittering agent, commonly denatonium .
So
an the treated ethanol be used as shellac solvent/thinner? While it's more expensive than big box DNA, Kleen Strip is up to 60% methanol (!), I'd spend the difference if there's no effect on the resulting film strength.
Any users here?
Re: So
Only two things are important- will it dissolve and will it evaporate?
If I needed ethanol to dissolve shellac I would go to Ebay, search ethanol and buy the cheapest stuff I could find there.
Local turners are buying ethanol in 5 gallon quantities for drying turnings but I don't know where they are buying it. Most places have a chemical supply place that will sell ethanol in quantity.
green can...
David Weaver
.I don't know if this is still current, but a while ago when getting into using shellac, I read a bunch of MSDS sheets, and the green stuff from klean strip didn't have much methanol. The standard can had a lot as you say.
https://shop.paxtonco.com/storefrontCommerce/binaryContent.do;jsessionid=B1EFEE0793C0356D4C2453F647B48DC7?contentKey=2fd3f71d-a78b-4d73-9f15-078b1b8840e9
This MSDS was posted in 2015, so it may be worth contacting K-S to see if it's still updated, but it shows methanol less than 5%.
I've never had any issue with shellac dissolving in it, including a relatively slow dissolve of flakes over 10 years old (but it still dissolved and I think the advice to throw away old flakes is bad advice unless one can't bear to have a jar sit on a shelf for a couple of days). The slow-dissolving shellac seemed no different in use once dissolved.
Re: green can...
Wiley Horne
Agree. Here is MSDS for Klean Strip DNA, taken from Woodcraft website:
https://www.woodcraft.com/media/W1siZiIsIjIwMTkvMTIvMTgvMDcvNDAvMTcvOTU4LzE1NDcxNy5TRFMuMTU0NzFTLnBkZiJdXQ/154717.SDS.15471S.pdf?sha=1a8f64f349a81575
—Ethanol……85-90%
—Methanol…<=5%
—MIK………….<3%
Haven’t tried Everclear from the liquor store—95% ethanol, but I think the rest is water. Not available in all states.
Absolute alcohol, up to 200 proof, available from lab supply places—super expensive and you need some kind of certification to buy it.
Wiley
"pure" alcohol
Sir Google tells me two things:
1) 95% (95.6%) Ethanol is the highest concentration of ethanol you can get by distillation because 95.6% ethanol is an azeotrope, which means the vapor state has the same ethanol-to-water ratio as the liquid state.
2) 100% ethanol is possible, just not from typical distillation
I buy Everclear, not for drinking, but to make pure vanilla extract. I prefer to use vanilla beans from Madagascar. A bottle of pure vanilla extracted from the beans is a great present for those who bake. During the 1st part of the pandemic I bought it to mix up hand sanitizer to give away when it was unavailable anywhere. Then an angel sent me many gallons of hand sanitizer and my circle of distribution suddenly got MUCH larger.
When I buy "pure" isopropyl alcohol it is always 99%. I read somewhere that that, too, was limited by the normal distillation process.
100% ethanol
there are various way to make it. For example, it can be cheaply made from ethylene with no water involved and hence no water to enter into the distillation. But if the ethanol is made by fermentation then the water must be removed. Water can be removed by distillation by using a cosolvent that azeotropes with water at a different boiling point than ethanol. Benzene used to be used. Also can dry out the water with molecular sieves, then recycle the sieves.
Re: "pure" alcohol
Happened to come across an article for removing the last bit of water from ethanol. Stated this was done in "industrial" quantities, but I tried it on what I had in the shop, that being DNA at 7% methanol +. I was having an issue with my shellac actually puckering and raising the grain on raw wood. The problem was the water content in the alk. So how did he remove the water from the azeotrope to get pure alk?
Dry Tapioca! When added to the alcohol, it soaks up the water but not the ethanol. The grain is then strained out of the liquid and laid out in the sun to dry (or put through an industrial drier) and reused.
I was a bit skeptical. Went to the food store, got a pack of tapioca, and proceeded to try it. I took an amount of the dry grain and weighed it on my gram scale to 1.000 oz.; then dumped it in a pint of DNA with a tight cap, shook it occasionally, and let it sit over night.
Next morning I poured it all through a fine sieve to recover the tapioca, and weighed the grain in the same cup. Didn't write down the weight but it was clearly more than the original oz. I then spread it on a clean baking pan put it out to dry in the hot sun. When the stuff was very dry (subjective, I know) I put it back in the same measuring cup and weighed it. Came up to exactly 1 oz.
Lastly, I used the pint of alcohol to mix a 2lb cut of shellac and applied it to some raw red oak that I sanded to 320 and vac'd well. Hey hey hey! No raised or puckered grain; just a nice even gloss on the surface.
I also prefer my martinis extra dry :D
Vanilla extract
I'm cheap - I just use reasonable quality vodka. It takes a bit longer to extract, but works quite well.
