MM to Inches
Larry Edinger
I have a Plan that is in MM, how close should I be when converting to inches ?
Thanks
MM to Inches
Larry Edinger
Thanks
Re: MM to Inches
If it is the length of a table sitting in the middle of a room, to within 10 mm would be fine. If it is a book shelf that has to just fit between windows 36 1/16" apart then to within 1/2mm. You see that the answer to your question depends on where the dimension will be used.
Personally the one time I worked from a plan the plan was wrong and I never did that again. In your case I would redraw the plan from scratch, in inches, making every part fit in inches.
Re: MM to Inches
Mark Nowicki
Why do you want to convert?
I would think metric tapes are available everywhere.
Re: MM to Inches
Metric lumber thickness aren't.
Re: MM to Inches
TomD
It depends on the plan. Say you have a plan to make a CD shelf. At the end of the day you need the CDs to fit. It becomes less an issue of resolution, and more one that you get a result that holds CDs. There might be little difference in whether the shelf was one meter, or 3 feet wide, but height and depth will be critical, and you could just convert to inch dimensions that work in that case.
Another issue are standard dimension products. For instance our plywood is sold in 4x8 sheets. Things like locks may be designed to fit standard imperial dimensions.
Normally I just either plug numbers into an online conversion tool, or use 25.4 = 1"
A good way to eliminate error is to read across a dual tape. However, in my shop I have only metric tapes and imperial tapes. I don't own a dual tape, but tapes these days are under 10 dollars, I have some really nice ones that cost around 5 bucks. In Canada the default tapes were dual, but that seems to have changed. I hate them because it always seems to work out that the way one needs to hook the tape, the measurement is on the wrong side for marking. However it can be handy for conversions.
I have been using metric my whole life, but I still find I can get lost, way out there on a metric tape. Certain characters repeat over and over, and it is easy to get lost. So be sure to double check
Re: MM to Inches
Couple of things:
First: We (most of us) as Americans are not used to thinking in Metric and it is quite easy to make errors (as Bill stated).
Second: Although not pertinent to woodworking the American measurement in actual lab use is more accurate than the metric - what is .000001 in metric? . This was analyzed by Scientists and published with data.
I worked for about 40 years as an Engineer, our fairly large factory had about 1200 employees when I started.
We produced many electrical components / switches etc for GM during my tenure. GM did require that the blueprints were in metric in later years but all were in BOTH English and Metric (both ours and theirs).
Personally if I were building something from a Metric print I would at least convert and add the American measurement to every dimension of the print. Calculators with built in conversion buttons are about $10.
While I am quite educated on Metric dimensions, I still "Think" in English and mentally convert the dimensions in question to Inches and thousands of an inch.
Re: MM to Inches
Mark Nowicki
Assuming one starts with rough lumber it is not too hard to plane it down to 19mm.
Re: MM to Inches
Larry Edinger
What I'm Building is this; https://www.paoson.com/en/shop-woodworking-homemade-tool-furniture-plans/86-homemade-saw-blade-router-bits-sharpener-plans.html
Re: MM to Inches
Mark Nowicki
Looks like BB plywood which is sold in mm thicknesses anyway.
Funny thing...
John in New Mexico
The US plywood from Home Depot and the like might as well be metric too
23/64" for crying out loud
I use BB plywood a lot. Excellent stuff.
Re: MM to Inches
Larry Edinger
I know the Ply is in MM, I'm talking about the Measurements of the Parts
Re: MM to Inches
Mark Nowicki
Round up to half of the smallest division on your measuring tool.
This one. Redraw in inches.
Re: MM to Inches
let us know how it works.
It costs $12 to have an 80 tooth blade sharpened at Misenheimer, Morristown, TN. I predict the home made sharpened blade will not cut as well as when new because the tooth geometry will be difficult to reproduce on every tooth.
For this job I would buy a metric ruler and build metric.
Re: MM to Inches
Larry Edinger
Just Bought a
Standard to Metric Conversion Calculator
Re: MM to Inches
Any calculator will do the conversion, or easiest is to Type "convent mm to inches" in Google and fill in the blanks.
Seems a tedious process compared to just building it with a metric ruler.
I build English, but I find it handy to measure metric often enough that I have an assortment of metric rulers. Sure is easier dividing 846 mm in half than 23 13/16.
Re: MM to Inches
GolfSteve in Calgary
What would your tolerance be if you were using inches? Multiply that by 25.4 mm per inch, and that is your equivalent tolerance in mm.
For example, a tabletop dimension could be acceptable ±1/4", which is about ±6.5 mm. So if the drawing calls for a 1000 mm long top, you could cut it anywhere from 994 to 1006 mm and have approximately 1/4" of tolerance.
The thickness of a drawer side might be a nominal 3/8", but it's not a critical dimension, so anything close to 9.5 mm is good enough.
If many cases, the exact dimension is not critical, it's just important that the pieces match. e.g. a tenon can be 10 mm or 3/8" - doesn't matter as long as the mortise width is the same as the tenon width.
I have a gut feel for different things in different units. For furniture work I mostly use inches. For weight I use metric, except for body weight, which is in pounds. For distances I use metric, except for body height, which is in feet, or very small tolerances where I use thousandths of an inch. For pressure I use kPa, except for pump discharge pressure, which has to be in psi. Bolt sizes are imperial unless I'm working on my bike. For volume I use metric, except for beer which is in pints (unless I'm in Australia where my preferred beer volume is a schooner, or in Germany where my co-workers will blackball me if I order a glass instead of the required litre of beer which gets warm before I can finish it).
Here is the problem
The planes are not for a table where it doesn't matter how big it winds up. Rather the plans are for a jig. It may be difficult to know what dimensions are critical and what are not. For this reason I would have built it with a metric ruler and then when it didn't work I would know it was the design and not construction.
Whoever proposed this device does not understand how critical tooth geometry is in blade performance. There is no way this jig can grind a blade with the accuracy it was ground at the factory. There is not much savings in screwing up a $100 blade as an alternative to having it professionally sharpened.
BTW, an Alexa device can do remarkable shop math.
Stephen Roth
And it is a no-hands operation. I end up using it more and more.
Re: MM to Inches
Walt
"Sure is easier dividing 846 mm in half than 23 13/16."
Even easier if I were dividing 846 mm into 5 or 6 equal parts. Just don't use a mixture of measuring systems. NASA tried that, it didn't work out well.
