House-Made Chisels.. (not booster!!)
David Weaver
..for those tired of boost or not boost and wanting to see something made.
I made these chisels, forged, or forge shaped (go ahead, and say it "forged in fire!!!") out of what's essentially similar to japanese white steel, or like 1095, but then cleaner plus a bunch more carbon.
they are for the former toolmaker at colonial williamsburg, who surprisingly, asked if I'd make some for him, and while I'm not a blacksmith or commercial metal bits maker, I challenged myself to make them well and to also snap steel samples and come up with a thermal cycle that doesn't have to be done in a controlled furnace, but that will yield very fine and durable edges (the steel is also warpy in heat treat, but I was able to work past this).
http://www.woodcentral.com/woodworking/forum/handtools.pl/page/1/md/read/id/501093/sbj/not-quite-as-junky-parers/
Many here may not tread over to that page to see the repetitive posts I've made about venturing into chisel making.
You may be struck by the ugly file handle when you look through the three pictures, but no worries - that's temporary to test them. The person getting them wants to make his own handles.
they're more or less modeled after something kind of hard to get here in the US for a reasonable price - good English paring chisels with a forged bolster (and the bolster is forge welded in place, which makes them "real" chisels in every way that I can think of)
They are hand made/hammered and hand filed and freehand ground to shape.
Re: House-Made Chisels.. (not booster!!)
final version of these...and gombeira
David Weaver
I mailed these out yesterday (pictured with two rejects from the process that I put handles on and will keep myself - they are more than good enough for me, and I'm happy to keep them without finishing them as nice cosmetically - the five without handles went in the mail, though).
the interesting thing about the brown handles is that the wood is gombeira - brazilian ebony, and probably 10 other names - it's not ebony as far as I know. It's like a cream color under the surface and even though it's finished with shellac and there's little natural light in the shop, it darkens quickly. This is a picture probably from about 2 weeks ago. Exact same chisel as the narrower handled chisel above (the five that are better finished have been mailed off to someone who makes their own handles - and just for clarity, i'm not free riding on woodcentral to advertise making tools - I don't charge more than the cost of the steel, gas and grinder belts to make them and sometimes nothing (in this case, they are a gift to the recipient). When you get into cleaner specialty steels, the cost in making and the belts can be considerable (about $80 in the case of these five just for the materials, but good chisels can be made from less expensive steel - these are just going to be slightly better than chisels made of O1 or something else that pretty much anything on the open market is made of).
And after some paring (I pared off about 1/8th of this rosewood blank before finishing) that destroys every plane iron that I've put to it due to silica (if you sharpened the chisel to a point vs. following the unicorn article shown in the artices on WC, it would also damage the chisel). Wood of this type, same rosewood from the same seller actually resulted in accidentally discovering the "unicorn modification" as the silica will damage an edge on the first pare. The accidental discovery results in an incannel gouge that will scratch cosmetically on the outside surface but the edge won't get damaged by silica that does it).
That method and these paring chisels is a match made in heaven. Paring directly across rosewood end grain without some slicing motion is less heavenly.
As far as making tools goes - it's not that much different than making furniture or other woodworking that requires a little bit of freehand finishing or detailing. If you can do one, you can do the other, and these chisels could be made with a half decent belt sander, a ceramic belt and a piece of railroad track to use as an anvil to hammer the bolster on. (well, and special quench oil - but that can be avoided by using O1).
The picture below shows what happens to the most chip resistant plane iron that I have even with some edge modification - so much angle needs to be added to both sides of the iron to handle planing this that it's almost impossible to push the plane. Not very practical. What works really well for all but the very final fitting with wood like this is a power sander or carbide teeth!
(it should be obvious looking at this what the silica does to the edge of the plane iron, but the chisels go through the silica and who knows what - they either squash it or push it above or below).
Fourth pic..
David Weaver
apparently, the page doesn't like me adding a picture during edit, so the last of the pictures mentioned is below - note the lines from the edge of the plane iron being destroyed. This damage stops when the plane iron edge totals about 50 degrees included (which is about 60 effective - not so good for planing end grain) - well, it doesn't stop, but it's a lot less.
with carbide tools and sandpaper, of course, you might not even notice silica. It's just very subtle little loose bits that sit on the pores - you can just blow into the wood or brush it and they come out, but the next shaving you take off, the ones below show up again - it's uniformly dispersed throughout.
These planed lines show up in about 10 strokes and the plane ceases to cut soon as the edge is blunt with foils and dents.
Re: Fourth pic..
Ivan Clark
Beautiful work!
Thanks for the description of the chisel vs plane blade. The information should carry over to turning as well.
Much appreciated.
