Torah Scroll Case on Stand *LINK*
Alan Young
Alan Young
Hi Friends, I just finished a project that was in the works for quite some time. Rather than load this post with a lot of pictures I am just posting a link to my webpage with a full write up of this project-a Case on Stand for a Torah Scroll. at the end of this link is another link to a page with progress photos of the fabrication process.
Regards,
Alan
Re: Torah Scroll Case on Stand *LINK*
Another wonderful piece Alan - thank you
Henry (Raleigh NC)
Great to see work like this!
You ought to at least add one 'teaser' photo to this thread.
Wonderful and unique work.
Henry
Howard Rosenberg
As always, beautiful work.
The Torah looks new - did they commission it themselves, or buy an existing one?
Thank you for the link to the page where you explain things.
Alan Young
Re: Another wonderful piece Alan - thank you
Alan Young
Thanks Henry-Good idea- I just added a photo.
-Alan
Alan Young
Alan Young
Hi Howard-
The provenance of the scroll is mid-19th century Romania.
-Alan
Wonderful Craftsmanship, Alan.
Wiley Horne
Hi Alan,
This is a stunning accomplishment! The mechanical works are ingenious in allowing the Torah to be scrolled in the rollers and read, while under protection of the glass. The iconography of the pierced work supporting the rollers adds specific meaning—is it Tree of Life motif?
Above all, what is striking, after you look a bit, is the way the scroll motif is carried through the whole piece—the scrolled finials at top of the lyre legs, the scrolled finials of the top, the capped brass rods.
The photos show how many peoples’ lives and hopes were pulled together by their participation in this great piece of work!
Thanks for showing, Wiley
Howard Rosenberg
Thanks for that, Alan.
I always find it interesting where Torahs of different ages are found - especially from Eastern Europe.
Along the same lines, our synagogue just completed the purchase of 2 Torahs from the 12th century - one from Iraq, the 2nd from Syria.
questions
1.What went into the decision to include the sap wood in the front side?
2. What are the steel? things poking out from the sides, functional, decorative?
Alan Young
Wiley, Bill and others
Alan Young
Wiley and Bill and others,
Thanks for your comments and observations-
as to some questions.
Bill-
As to the Sapwood and other visual impressions one might see in this piece. I have decided to let the viewer choose what he/she might see in it and develop their own interpretations. I do/did in fact have "artistic" reasons for certain elements of this piece but do not want to express any of my personal choices. Rather I'd be more pleased to know what others might see in my choices that I may have never intended. If someone observes an element that I intended to cause a certain response by a viewer-fine if not just as well. So as to the sapwood, yes there is a reason I put it there-but I won't force that impression on anyone-I'd rather let it speak for itself even or "especially" if it may not satisfy someone else's artistic design sense.
The "Steel" pieces are actually Brass.
They are quasi functional and quasi artistic with an intentional "artistic" reference but as with the sapwood-I'll allow it to speak for itself even if if my intentions are not communicated accurately to the viewer.
This entire piece will be used in two locations. It will reside in a library for most of the time but will be moved to a classroom on occasion. The requirement of it being "movable" meant I had to accommodate the entire design to fit through a particular doorway and it's particular door handle height. That dimension drove a long series of design decisions totally out of practicality. The other element is the roller designs-They were chosen by the librarians. I should have taken pictures of the rollers when they first arrived as the were each in one long section.
Imagine the top and bottom pieces each joined together with and additional 6 inches or so.
I cut the middle section out of the two rollers to allow the scrolls to be in the aforementioned closed position or open position, Closed allows for approximately two columns of text to viewed-That is how one sees it with the case lid on..
Open allows for nearly four columns of text to be read-That is the function in a classroom setting with the case lid off.
One last photo- regarding the "scroll element." I was well into the process when I decided to carve scroll elements into sections of the base. I had hoped to "pop" the elements with gilding in the finish process. Needless to say they faded into the background and are only seen up close---I decided to let that be and not do anything that would bring out the detail....
Re: Wiley, Bill and others
So the brass thingies are handles for carrying it? Didn't realize the cover lifts off. So the top scrolls are handles for the cover....clever.
How do you treat the brass in your pieces to prevent corrosion over time? Lacquer it?
Alan Young
Not sure if you saw the other "operational" photos
Alan Young
The top of the base is designed to allow the scroll to be viewed and rolled with the case on or off.
The scroll sits on rollers that are fastened to two movable plates.
Moveable plates are shown in the "closed" position before the scroll is placed on the rollers.
Here I am placing the scroll on the rollers.
In this photo the plates are pulled to the open position which allows four columns of text to be read.
The plates need to be in the closed position for the case top to be set in place. My good friend John Hilligonds helped me deliver the piece and is shown here as we place the case top over the scroll and the base.
Masterful
What an excellent project, beautifully conceived, very nicely done, and perfectly documented with the full back story. This is yet another masterful accomplishment, Alan. You continue to amaze.
Thanks for sharing it all with us.
Torah history and usage
Wiley Horne
A helpful write-up on the Torah and how it is used:
https://www.bbc.co.uk/religion/religions/judaism/texts/torah.shtml
Wiley
Alan Young
Re: Masterful
Alan Young
Thanks Ellis, I was very fortunate to be able to work on this project. It came about right when I was leaving the day job for good. We'll see what woodworking looks like on "the other side."
Alan
Alan Young
Re: Torah history and usage
Alan Young
Wiley,
Thanks for that link! Very informative and helpful fur further understanding.
Alan
