Not really furniture
It has been a little slow here, and I thought I'd post something that - surprisingly to me - received a lot of positive attention on another forum. Some here may find this interesting. It is a little Off Topic.
I am just getting back to my hifi system after some 25 years of being satisfied with background music. Until recently, I last purchased any equipment 35 years ago!
Some three months ago, a good friend purchased a new turntable and began rediscovering his old albums. This awakened so many memories that I decided to get my system back together again. That was the plan, and I began researching on forums, watching reviews on YouTube, and it became apparent that the decades had past me by, and there was a whole new world of new hifi to explore. 30 years ago I was a vinyl enthusiast. But small kids and big dogs - with even bigger wagging tails - did not mix well with turntables and expensive moving coil cartridges.
I had a Thorens TD150 (Mk I), which I purchased in the early 1980s, At that time it was already about 20 years old. For the fellow-addicts here, it came with a SME 3009 series 2 tone arm which, after a half dozen years, I swapped it out for a Rega RB300 arm, as this was considered a better arm for a moving coil cartridge. Then, in the late 80's I moved from Sydney to Perth, and life became too busy to devote any time to hifi.
In 2010, I built an entertainment centre based on twin campaign chests. The idea was to leave space for the hifi, like this ...
I made the error of showing my wife, Lynndy, what it could look like with added drawer fronts ....
At that point she decided that twin chests were better than an entertainment centre, and that was it!
The TV was sited on one, and my hifi system became reduced to CD and DVD. The turntable and other equipment were banished to another room.
Here you see it with one (of a pair) of Bowers & Wilkins DM 7 (Mk 2 ) speakers - again, for the purists here. These are now 40 years old (and I have had them from new)!
My plan was to re-build the Thorens and get new speakers. Lynndy hated my B&W coffins, and had nagged me for years to get something smaller. And so I did - Kef LS50 Meta speakers on stands. Quite amazing for such small speakers. Their imaging is extraordinary.
Now I needed to move the equipment off the cabinet. Time to add a matching stand for the equipment. Again built in Jarrah (in the picture is the copy of the Hans Wegner chair I made several years ago) ...
New to me (but not to others) is streaming. I purchased a Cambridge Audio CXN (V2) streamer/DAC, along with a subscription to Tidal (for their master disk recordings) and began ripping all my old CDs to FLAC files, which is stored on a SSD drive attached to the CXN. I was planning to add Roon (to integrate a number of digital sources), which is where an old MacBook Pro came in, but eventually decided that it was unnecessary. The amplifier is a Harman Kardon HK6500 (high current and high power) from the 1980s (which I searched for and found on the German eBay). This has been serviced and reinstalled (a great match for the speakers, and it has a pre-preamp for a moving coil cartridge - most modern amps do not have these). The HK absolutely blew away the modern Cambridge Audio amp I was using in the CD system - a win for vintage amplifiers!
Construction of the stand is Jarrah, with a through dovetailed case. The shelves float on pins to decouple any vibration.
The tray slides out for the laptop ...
Let's not forget that this adventure started with the turntable and its re-build. So let's go there. This is how it looked originally ...
For those who are (incredible as it sounds) uninformed about the construction of this venerable lady, the plinth is about 1/4" thick veneered ply, with an even thinner hardboard base, and all this resolutely - or should that be resonantly - stands on tiny rubber stubs for feet. An absolutely brilliant design (suspended chassis) with inadequate clothing.
I fashioned a new plinth out of a 1" thick pinky fiddleback Jarrah ...
Construction-wise, the mitres are glued with a sizing technique (use glue to seal the end grain straws, allow to near-dry, and then glue again). The corners are reinforced with splines internally.
I did not realise that the upper plate on the turntable was glued on, and my effort in removing it caused a few kinks. Rather than purchase another, I flattened it, and then sanded it within an inch of its life, finally deciding to just clear coat the aluminium rather than a spray painted finish.
It goes back with double-sided tape.
I do not plan to go into the technical details of the chassis design, modifications made, or tuning up, but will mention that the RCA plugs and power socket were set into their own custom plates (which may be seen two images down).
I went a little mad with black acrylic (chosen as it absorbs vibration so well). First there was the base in 10mm thick ...
The feet are made from IsaAcoustic IsoPucks, which I modified by superglueing on stainless steel bolts to create feet with isolation properties and fine adjustment ...
The other area with acrylic is the armboard. This is pretty dead (vibration-wise) compared with the MDF original.
The Rega RB300 arm was modified with the Origin Live counterweight and coupling, as well as the VTA adjuster.
Finally together ...
A great deal of attention has been given to reducing possible vibration to a minimum. Even inside the plinth and the turntable, Dynamat was further added to dampen this. One of my concerns was that the turntable was to sit on a chest of drawers, and this may act as a sound board. The floors are Jarrah-over-concrete, which helps.
An isolation platform was in order. More acrylic as it seems to soak up vibrations ...
The top is loose and there are thin Sorbothane feet underneath ...
Here is the final affair. The perspex lid was custom made/sized for the plinth.
Close-up of the isolation platform angles ...
Cartridge? For the fanatics here, a Supex 900 Mk IV.
I have Linn hinges to connect the lid to the plinth, but am still sitting on the fence whether to use them ....
Re: Not really furniture
Beyond impressive
Yonak
Your attention to detail and especially to vibration mitigation is unmatched in any home system I've ever seen. Congratulations on an enviable audio system, Derek.
Brad Chenoweth
Derek, your attention to detail in the research, design and execution of every project you undertake is simply amazing! You continue to set the bar so high that we mere mortals can never hope to reach it. They are however, a constant source of inspiration and sheer enjoyment. Keep them coming!
Don Stephan
Great work, of course.
So, will the first album played be Count Basie band at the Newport Jazz Festival, with that astounding last song to show off the sound system? Or a BB King or Janis Joplin? Woody Herman, or Satchmo and Ella? All would do it justice!
Don, a lot of 60’s jazz. All of those you mention, but especially Bill Evans. :)
I am trying hard not to be an audiophile, that is, someone more interested in the equipment than the music. There are many woodworkers like this, collectors of tools than users. I like building furniture. I like listening to music. Good equipment can enhance the pleasure, but is not critical. In the case of accessing great music played well, I must shout out to the Cambridge Audio CXN (2), which is a streamer, and Tidal, the source of master tape level content (better than CD quality). I have at my fingertips some 7 million albums. It is mind blowing. So why vinyl then? There is something more intimate about the rituals involved with preparing and playing a vinyl record that one does not get from a digital signal. And vinyl (on a good system) can sound better - this means, better clarity, better separation of individual instruments, listening deeper into the music - one can create a 3D effect with sound.
This is a great - and fun - video to help explain:
https://m.youtube.com/watch?v=6qHvOaUYwWQ&ebc=ANyPxKpWtib_WUeScM9zVZ9atWtSHGRTVaBiTKS2zwuNzSZ18iNt8kWGqrmtMXne0PbWjvGh5ndH63vPeOn6DUq6rm5JT72ugQ&feature=emb_logo
Bruce McCrory
Your updates look very nice, Derek.
I used to listen to vinyl with the speakers positioned to focus the sound on my head. It was a very personal experience; even when the scratches were bad. Forty years later I found myself in the same position listening to vinyl on expensive audio equipment at a music store. I was looking to buy a decent headset.
I could have walked out of the store with several thousand dollars in equipment and a few newly cut albums. All of that for the privilege of hearing pops and scratches from analog equipment. [Note, it's a bit hard now, with poor hearing, but I can distinguish well engineered sound from normal crap.] Regarding squashed sound from ruined music, it's all that way now.
Gosh, Derek...
Jim Dillon
... given your penchant for detail, I'm surprised you have not installed those $30,000 audio cables that Mr. Fremer has in his home hi-fi system (and that he swears by!!). :D :D Anyway, enjoyed very much your recent adventures and loved your redo of that vintage Thorens turntable. Mr. Fremer's retelling of his experience as an expert witness, working with trial lawyers, brought back old memories for me - for better or worse.
Jim (who has way too much vintage '70s broken stereo stuff in his garage :( ).
Re: Gosh, Derek...
Jim, about those $30K cables ... :)
Actually, 30+ years ago I used to roll my own ... cables, that is. Truly (you did not hear me admit this!). Cables can actually make a difference (even Lynndy will attest to this, being subjected to my many experiments all those years ago). However, you really need decent equipment to hear this.
I think that some audiophiles purchase hifi equipment as some woodworking hobbiests purchase tools. Whatever floats your boat. One does not need $30K cables, however decent cables are necessary, and they do not need to cost much. It is amazing the varieties there are available, the hype, and the costs!
I have a set of custom speaker and interconnect cables (for the turntable) from a Australian company that go by the delightful name of "NB Speaker Cables". This stands for No Bullshit Speaker Cables. They make superb cables without the hype and price tag (the speaker cables came to about $200). Below is the interconnect cable. Beautifully made ...
