OT- Gluing Concrete?
Tom Norton
My wife has a small piece of garden sculpture,,a rabbit, one of the ears broke off. It is a pretty clean break. Wondering what adhesive to use? Silicone??
Thanks in advance!!
Re: OT- Gluing Concrete?
Don't glue or silicone  *LINK*
Mike L
I would use cement to attach the pieces. Here are the instructions I have found that have worked for me.
Repair
Re: Don't glue or silicone
Tom Norton
So my first idea, I didn't mention, was to use my West System Epoxy. I will thicken it up a bit.
Thanks!
John in NM
Epoxy probably. Sure to darken any area of concrete you get it on however. I think you're right that thickening will help that.
I think this will work better than straight portland cement (from Mike's link). Granted I've never tried this but portland is not an adhesive product, I just can't see it making a stronger bond than the original concrete that broke. I think I would try an anchor cement product instead if I wanted to go this way instead of the epoxy. They set up really fast - like about 10 minutes working time. I think they have a fine silica aggregate in them with something like calcium chloride to speed the reaction (this is just a guess however).
Silicone, well maybe.... It would work if surfaces were very clean and not crumbly and you didn't try to wipe off the excess. Carefully cut off squeeze out with a razor blade once it's cured.
With any of these, the hard part is supporting the ear until the product is cured. None of these will likely hold on their own when wet. Dry run of clamping is a very good idea unless you have the patience to sit there and hold for a while (I never do).
Kneale Brownson
Elastic bandaging to hold in place?
Kneale Brownson
Would a thinset mortar work?
kneale brownson
It holds tiles on shower walls.
John Veerkamp
I used epoxy to repair the arm on a neighbors fountain statue 3 years ago. Looks good and still holding.
Re: Elastic bandaging to hold in place?
John Veerkamp
agree. we used to call it Vet wrap.
Why not gorilla-esque family?
Tom Dunlap
I broke a concrete patio decoration and used a gorilla-esque PE glue. So far so good.
Is there anything wrong with it?
Perfect!
John in NM
It is a rabbit sculpture after all :D
