wind vane
wind vane
wind vane
Ray Mtn. Home Ar.
Between jobs in the machine shop. Its to hot to work on wood in the pole barn so I dug out some scrap copper and stainless rod and made this. It still needs to be cleaned up a little.
Re: wind vane
Re: wind vane
Philip F Duffy
FYI, the Abby Aldrich Museum here in Colonial Williamsburg has a fascinating collection of early American weather vanes which you might find interesting and inspirational should you have a chance to visit. P
Re: wind vane
Re: wind vane
Howard Rosenberg
That looks great.
How thick is the copper? And how do you mount it to your off?
Re: wind vane
Re: wind vane
Ray Mtn. Home Ar.
The copper is 1/16 thick and it will probably get put on a fence post 0r on the bird feeder.
Re: wind vane
Re: wind vane
Pete in Holland MI
Wondering about your pivot. I made a vane in high school shop class. Teacher had me us a pipe on the moving part, and a steel rod on the stationary part. Prior to final assembly on the roof, grease it, and put a ball bearing on the rod prior to assembly. Makes for a good pivoting point. Still pointing the right direction 35 years later (got greased a couple times since).
Re: wind vane
Re: wind vane
Ray Mtn. Home Ar.
It spins on a hdpe plastic bushing.
