OT - Printer Problem
Ralph Lipeles
I have a HP 2700 printer. It only prints half a page and then stops. I downloaded a fixit procedure. The first step states: Open the Start Menu - Go to Run. There isn't any RUN on my start menu. The "Type Here To Search" won't accept any inputs. Any ideas?
Re: OT - Printer Problem
Mark Nowicki
Look for the downloaded file in wherever your computer saves downloads;
Open file, Run.
Check the printer's paper size setting.
Use print preview to check what will come out.
Delete printer and reinstall.
Download latest driver.
Check for wireless conflicts.
Run Command
David Yoho
In Win 10 - click the Start button and scroll down to Windows System and click it. Look for the Run command in the list and click it.
Re: Run Command
Joe in a Cleveland suburb
Or right click the Start button. A different menu option pops up.
3rd option up from the bottom is 'Run'
John McGaw
Easy way: simultaneously press the 'windows' and 'R' keys.
I always forget...
David Yoho
that option is available. I created a shortcut to the Run command on the Quick Start menu that I use all the time. The trick to right click the start button is a good one but it takes the same number of clicks to open the Run command box when there's a shortcut on the quick start menu.
Bill Howatt
If you are like me and probably a majority of users you have one way of doing things and never think there might be an easier, quicker way of doing something. How many of us actually try and use new features when a Windows upgrade provides them?
There are numerous keyboard shortcuts in Windows:
https://www.thewindowsclub.com/keyboard-shortcuts-windows-10
billh
