New router?
New router?
New router?
A while back I posted about my 890 series router making noises. Turns out it is more than just the bearings.
As the PC 890 series router is no longer being made, parts aren’t inexpensive and are difficult to come by.
My usual adage about tools (and cars) is that when the cost of repair (and/or parts) exceeds 25% or more the cost of a new one, I really think about replacing tool (or car).
I don’t need a large router, I would prefer a medium power rather than a lower power. I am thinking about a DW618 kit with a fixed base and plunge base. They are also sold with a D handle.
Thoughts or recommendations?
Re: New router?
Re: New router?
AZ in Colorado Springs
I have the DeWalt. It's a great router. Both bases work very well.
Re: New router?
Re: New router?
Ryan
Just replaced an old router with the DW618. Seemed to be the best bang for the buck, I liked that it came with the 2 bases. Works great.
Re: New router?
Ordered DW618
Re: New router?
Re: Ordered DW618
Steve Elliott
DeWalts are the best routers I've used. I have two 618s and a 625 in a router table.
The collets are a little different and removing a bit requires loosening the collet nut twice. After it's loosened the first time it will turn easily a couple of times and then get tight again. The second time seems to pry the collet open and then the bit will slip out.
The collet grips the bit very well--I've never had one slip. The quality of the bearings and overall build quality mean there is less run-out so the surface quality of the cut is very good.
I'm sure you'll be pleased with yours.
Re: New router?
Re: Ordered DW618
Jim Dillon
JL, I think you will be very pleased with your 2-1/4 HP DEWALT 618 router kit. I have the 611 kit (1-1/4 HP) and it is a solid performer. I'm usually a Bosch fan but couldn't resist a good sale on the 611. Good choice! Jim
Re: New router?
Re: Ordered DW618
That trait of the collet is a safety feature. Freud routers also work that way. There is some pattern in the threads inside the collet that make this happen, and the effect is like that of a double latch on a car hood or the liftgate of a van.
Re: New router?
A.J. Hamler
My P-C 690 collet does that, too
