Resaw bandsaw blade question?
What do you use for a resaw blade on your bandsaw.
I have my 14" Laguna setup with a cheap locally welded blade but am planning to buy a resaw blade.
I considered the Laguna Resaw King, but I watched about half a dozen video's on it and in many cases they broke the blade. They were very happy with the cut but then the blade broke in a fairly short period of time. These are $150+/- blades.
I spoke to Laguna and they were somewhat surprised. They did say they moved their manufacturing to SC and the people did not move with it. They had Quality problems for a while, but the guy I talked to thought it was over and their blades had returned to their excellent status.
I am thinking it might be a good idea to buy excellent steel blades and treat them more like disposables.
What do you do?
Re: Resaw bandsaw blade question?
Dave's Not Here
I don't do a whole lot of resawing so it makes sense for me to just use 1/2" steel blades on my 14" Rikon.
howard gorman
I've used the Timberwolf blades 1/2" 3 TPI and like them alot.
A.J. Hamler
A.J. Hamler
Woodslicer.
Timber Wolf from Suffolk Machinery or Woodslicer from Highland Hardware.
I've used both - and they work reasonably well.
Bruce, a MN Galoot
I recommend Woodslicer, too. It is much less prone to wandering than other blades I’ve used.
Hmmm????
I have ordered two of the Suffolk Machinery blades. I may try the one from Highland hardware next.
My only problem is they cost about a 1/4 of a very expensive highly rated carbide tipped blade. Maybe the carbide blade is not such a bad deal in the long run????
Re: Hmmm????
Bruce, a MN Galoot
I also have a Lenox Trimaster blade, 1/2”. It does last a long time.
However, the cut I get from the Woodslicer is better. It also tracks better, due to a much thinner kerf.
It all depends on what you’re going to do with it. If resawing wood to dimension, get the carbide. If you’re going for something closer to finish, go with the Woodslicer.
Re: Hmmm????
Walt
Bruce, how's the life on the Wood Slicer? That's the only complaint I've heard about them. Some take the time to resharpen them.
Re: Hmmm????
Bruce, a MN Galoot
I like my woodslicer so much I leave it on the bandsaw. It must be five or six years old. I switch it only when I need to cut curves because it won’t do that but then it goes right back on.
