ADVERTISE HERE - FREE TRIAL
Speaking or chop saw blades for Aluminum?
Somebody mentioned a chop saw blade for cutting aluminum. I think. I need one for a 12" chop saw to cut the extruded aluminum rails for stair lifts. Any suggestions would be appreciated.
Re: Speaking or chop saw blades for Aluminum?
William Duffield
This one is not the right size, but the tooth geometry, etc., are correct. You can use it's specs when searching for one that will fit your saw.
https://www.amazon.com/Festool-494607-Aluminium-Type-KAPEX-Mati-Alu-mm-260-Al%C3%A9s-3/dp/B0017VHGR6
Don Stephan
Perhaps you could inquire of a sawblade manufacturer. When I was cutting 1" aluminum pipe on my now antique 8" miter saw I had very good results with a triple chip geometry I think.
Mark Nowicki
When I was cutting aluminum extrusions for a living I made hundreds of cuts with a Vermont American blade (negative 5 degree hook, thick plate ).
Did not lose a single tooth. Lubed with tallow before EVERY cut.
Do be careful, aluminum tends to grab the blade with amazing force.
Also the shape of the extrusion affects the grab, U-shaped or extrusions that are open on one side are especially dangerous. Safest way is to start the cut through the closed
or solid side.
Safety glasses are not enough, wear a full face shield.
Andy Lincoln,in Dearborn MI
I cut aluminum all day long with this blade: https://www.homedepot.com/p/DIABLO-12-in-x-96-Tooth-Laminate-Non-Ferrous-Metal-Cutting-Saw-Blade-D1296L/203162568
