OT - best way to clear a bathroom sink
Howard in Toronto
Used my consumer-grade sink auger to clear the clogged bathroom sink.
Worked perfectly. Two attempts and it got everything.
Went back in a third time thinking I'd get every last bit.
Yup. You guessed it.
I must have jammed SOMETHING waaaay down the pipe because now the water does not move at all.
Reluctant to call the plumber just yet.
And don't want to use Draino.
Thinking of using boiling water and Dawn dish soap.
Does anybody have any other ideas? This blockage is further than 16 inches away from the sink.
Re: OT - best way to clear a bathroom sink
Wiley Horne
You’ll be time, aggravation, and ultimately money ahead if you call the plumber and let him take the connection apart and snake from the wall, and put it back together for you, replacing all parts.
It’s the same job you’re up against. He’ll do it for $99 while you have a cup of coffee and get the checkbook.
Wiley….knowing this isn’t the desired answer :)
Howard in Toronto
You're right - not my desired answer. But that's usually where I end up.
Thanks Wiley.
Mark Nowicki
16 inches or 16 feet?
Kneale Brownson
kneale brownson
Because I used to have a dozen rentals, I became used to DIYing these kinds of things. If you feel comfortable about it, take the drain apart under the sink--not difficult, just cumbersome. Look up a schematic of typical sink drains. Put a pail below the trap. Remember lefty/loosey; righty/tighty on the coupling nuts. If you CAN, take it off from the wall/floor drain and the sink without separating the trap assembly and pour the trap contents into the bucket. If you think you'll have trouble remembering how it goes together, take pictures and use a marker. Use your auger inside the wall/floor drain while twisting without pushing hard, to avoid getting the plug farther away.
If this is too intimidating, CALL THE PLUMBER
Howard in Toronto
16 inches
Howard in Toronto
Thanks Kneale.
Yes - definitely intimidating.
I'll check the link in the above reply and then prob just move on.
Many thanks.
Howard in Toronto
Yes
That looks like my results every so often.
Howard in Toronto
Just checked the above link.
On to Plan B.
Bill Howatt
While plumbing can be a PITA, this really shouldn't bee to difficult to do yourself assuming you don't have mobility issues affecting working under a sink and it is bound to happen again so it can be a skill worth learning.
Don't do what my friend did though. He drained the water from the trap into a bucket and then decided to get rid of the dirty water. He poured it into the sink to put it "down the drain". Unfortunately, it was the sink he was working on with the removed drain pipe and it all ran out onto the floor of the vanity and house.
Bill
plug the overflow hole and plunge the sink
David Weaver
...every year, my wife and daughter get the main bathroom sink clogged with hair and soap. The drain doesn't have enough room for a snake to go under the drain lid without taking the assembly apart.
A couple of years ago, I found out that what's in there isn't that solid, but it's solid enough to stop the drain and plunging it does the trick. I also learned that if you don't plug the overflow further up the sink, whatever you plunge (generally black hairy soap scummy stuff) will shoot out of the hole into the wall. Blech.
A thumb over the hole and one plunge has unclogged the drain every time since then without drama.
John McGaw
If it only that far down you might, just in case, disassemble the trap to see what you can find. Takes only a few minutes and doesn't cost anything. (put a bucket under the trap before disassembly!)
Yonak
I find this is the best way to deal with a blockage from the start.
Re: plug the overflow hole and plunge the sink
If it's 16" in, it's likely the plug is beyond the vent stack so a plunger won't work.
In the words of Borat
Howard in Toronto
Great success!
Nearly half a litre of Dawn. About six litres of boiled water. Four separate shots. My sink now drains.
It either cleared it all or it just pushed things further down. But the sink now works (until next time, that is)
Thanks, everybody.
YAYYYYYY!!!  Great work.
Re: In the words of Borat
Buck
Have I lost some of the pride I had in theses HANDYMEN!!! DIDN'T READ all the suggestions, did anybody suggest taking the
little ?trap? off & clean it out, would'aw been my first thing to do!!!! Oh well, WE live & learn!!!!!!!
NO, can't recall PROPER NAME FOR THAT little trap!!!!
"P" ;)
Buck
Thank Ye Mark "P trap" @'s it!!!!!!!!!!!!!!
There are two traps used on sinks (Bathroom &/or Kitchen). One is the "P" trap which drains through the floor - other is the "S" trap which enters the Wall.
"P" vs. "S"
Yonak
Logic tells me it's the other way around. I must be missing something.
Re: "P" vs. "S"
Wiley Horne
You’re correct. Also, S-traps are non-code in new construction for many years:
https://homeandgardenmakeover.com/s-trap-vs-p-trap-whats-the-difference/
Wiley
Re: Your correct - my memory fault!
Been a long time since I was a state licensed plumber (30 or so years), at that time many older homes had "S" traps.
