Thoughts re unfinished cedar for an outdoor chair
Howard in Toronto
I like the idea of unfinished cedar for outdoor objects - rot resistance etc.
But this chair will live outside 12 months a year - Toronto humidity and snow/rain/cold/aggro.
If I don't stain or paint it, do you have any thoughts re diminishing its greying over.
My fence, for example, seems to have sprouted little "tongues" that are lifting up. I'd be reluctant to put people in the position to get slivers by sitting in it.
I could buy pine and stain it (my other outdoor standby) but I've got a mountain of 5/4 white cedar I'd like to use up.
Thanks.
Howard
Re: Thoughts re unfinished cedar for an outdoor chair
Australian Timber Oil from Cabot.
A friend used it on a picnic table a couple years ago. Still looks reasonable today.
Howard in Toronto
Thanks JL
I just checked it out - do you have any idea re it letting cedar retain its anti-rot characteristics?
No. It was used on redwood. So I haven’t any data.
Howard in Toronto
gotcha
thanks
We used to make big driveway gates back in the day, usually of mahogany or teak. I ran several extended experiments with clear finishes and never found a single one that held up more than a year or two without recoating. So, unless you are prepared to replenish the finish annually, I'd suggest some kind of stain or preservative product that stays pretty much in the wood or whose failure mode is chalking rather than flaking. You definitely don't want to have to strip/sand/refinish a varnished chair.
As for those little tongues you mentioned, I found that to be a problem with flat sawn cypress, and the only workaround is to use quartered lumber, at least for those parts that could hurt somebody.
Howard in Toronto
Thanks for this Ellis
AZ in Colorado Springs
Those bits are the ends of grain layers "delaminating from it's neighbor, and warping/curving away into free space, correct?
