Chair leveling questions
I have built six chairs. They are sort of "cubic" in the sense All the angles are ninety degrees so the bases are parallelograms. The backs are 48" tall and there are long slender back splats. Put together with dominos. Very careful to calibrate and check all the cuts. Assembled them on my table saw to be assured of a flat planar surface. They went together nicely. Clamped them up and then put a bar across them and clamped them to the saw top. Let them sit over night and took the clamps off. They sat nicely with all four feet on the table. Moved them into the house to free up space in the shop. Now I am moving them back into the shop to give them a final sanding and finish.
Now they don't sit flat. The odd thing is that in every case it is the left rear leg and right front leg that seems too long. On some I would have to remove a 1/16" off the offending legs and on others it's closer to 1/32". On a side note, it's raining for the first time in weeks.
Questions....
Would you trim them to sit flat again or just let them go until they reach their new home one state to the south?
Would you install adjustable feet? (They are going to live on a hardwood floor.)
Should I wait until the weather changes again to see if that is what made the difference?
Perhaps I should sit my fat a$$ in one to see if they flex???
Any thoughts on why they are all wampuss in the same direction?
