Veritas - Innovation in Tools
Shop made dust collector hose boom.
Virgil Johnson
I made this boom to add dust collection to my PM 66 last spring during the shutdown. Can't remember why the stores were closed but that's another thread. I saw an ad for a boom online named for a Greek mythology god. If I'm naming this one its going to be called the "The Sanford" cause its built from junk. 1" x 1" x 1/8" wall steel tubing, 1/2" dia steel rod for the pivot rod, 1/2" EMT conduit for the extension. Misc cable ties and a short nylon strap.
I started by building a motor cover for the saw. A 99 dollar price tag for a plastic molded cover sent me to the wood rack to find enough plywood to build the cover. (plywood was scrounged from someone down the street tossing 3/4 of a sheet of 3/8" BC ply) The brown paint was from a left over paint sample. I would have used the standard dust collector port on the saw but the mobile base covered it so I ran 4" PVC through the motor cover down to the bottom of the saw base which I had covered in plywood. I have since moved the new saw port location lower to account for the coupler as shown in the 3rd pic.
I used Rockler 4" flex hose which is a very nice product.
The hose extends far enough to reach my work bench where it can be hooked to my router table. The hose tucks under the canoe when not in use. I did have to purchase the hose and fittings but most other items were on hand.
Re: Shop made dust collector hose boom.
Looks good, been trying to convince myself to rig up a boom over my bench to carry the hose in from overhead for my sanders and router etc. Just can't decide if stepping over them is any worse than weaving through them.
Added missing photo
Hi Virgil,
Great rig. I've uploaded the first photo in your post. Somehow it was among the missing.
Thanks for posting.
Best,
William Duffield
I have a rotating boom for mine (for hose and power). It's much more convenient than letting it fall on the floor or letting it drape over systainers, radial arm saw arms, etc. If it gets in my face, I just push it aside with one hand and up against the wall. Usually, it stays until I pull on the hose and rotate the boom. I mounted it to the bottom end of a length of allthread with a couple of nuts. The allthread is mounted vertically to a ceiling joist with some simple hardware and a couple more nuts. I screwed a line of screw hooks into the bottom face of the boom about 5 or 6 inches apart. The hose and power cord are bound to each other and hung on the screw hooks with some ball bungees, which allow me to quickly reposition the hose as needed, with one hand, by simply detaching the ball from one hook and hanging it from another. Originally, I bound the hose and cord with double sided Velcro tape, and just hung the cord on the hooks, but that didn't work well enough, so I added bungees until I didn't need any more.
Does anyone want some pics, or is this verbal description as clear as mud?
Re: Added missing photo
Virgil Johnson
Thanks. I tried to fix the post but can't get to the edit function. Anyone else have this problem? Fixes?
I was able to edit this post.
Editing posts
Our venerable software is set up to allow you to edit your posts within two hours of posting. After that, you need to contact an administrator with editing requests.
