Have a question? Ask Woody!
Can you spray SW Emerald Urethane Trim Enamel?
Pat Evans
Never sprayed before, but I have an old Central Pneumatic compressed air paint spray gun. SW doesn't have any published info on viscosity and their help line couldn't help. I need to know if I can spray the subject paint. All I know about the sprayer is that the manual says the tip size is .082" and maximum allowable viscosity is 60. Does anyone have experience spraying this product with a compressed air sprayer?
Re: Can you spray SW Emerald Urethane Trim Enamel?
Information you might could use
I spray any solvent based paint or vanish I have tried by thinning about 1 part solvent to 3 or 4 parts paint- DeVelbiss JGA gun. Might have to up pressure to 40-50 psi.
Hi Pat,
Looking at the available docs on this product, it appears very similar to Benny Moore's "Advantage" product which I used in my HVLP test in the Articles Section. Short line is I needed to thin the product with close to 30% added water to get the atomization needed for an even sprayed coating that leveled well. If you're fixed on the product, I'd suggest you by a quart (or other smaller amount) and do some careful experiments to get it right. Ask the paint guy for a recommended viscosity cup.
Also note that these waterbased alkyds take longer to dry. In that case, holding the target surface horizontal will do a lot to avoid runs or sags. It you have to do a vertical surface, back off on your material feed and use more lighter coats with time in between to let the film set up before recoating.
Why use a waterborne
Sounds like spraying a waterborne has to be done with more care to avoid runs, than is the case with a solvent based paint. Solvent based finish can be sprayed at higher viscosity because it takes less energy to atomize the solvent. And, a combination of faster solvent drying and the large viscosity response of solvent finishes to solvent evaporation (because they are dissolved polymers), the applied film will quickly have much higher viscosity that the material being sprayed.
I have never sprayed a waterborne. What are the advantages of spraying water borne paint(or varnish) vs a solvent based paint?
Re: Why use a waterborne
Don Stephan
My woodworking "shop" is within city limits, in a commercial district. During application for a building permit to rehab the building from a carryout thirteen years ago, the department employee made very clear if I had a commercial spray booth with exhaust, I would have to have a one million BTU makeup heater on the roof, even with a written assurance that I would only be spraying water borne products. I did not want to spray solvent based finishes, with or without a commercial spray booth with exhaust, and certainly I did not wish to pay for a one million BTU makeup heater.
I had several reasons I did not want to spray solvent based finishes. In my opinion, the lingering fumes from spraying solvent based finishes without a commercial spray booth with exhaust is not healthy. Cleaning the spray gun after use would require keeping a larger quantity of thinner, which would produce increased attention from the fire department's inspection, likely increase the cost of my building insurance, and produce hazardous waste that would require appropriate and expensive waste disposal procedures.
Beyond that, my appreciation for Nature and what Nature produces, including the wood I use to make furniture and turnings, would be inconsistent with casual avoidable pollution.
There is no question waterborne finishes do not spray with exactly the same gun setup and practices as solvent finishes, but I expect the same is true moving amongst some of the different types of solvent finishes. The same may have been true moving from first generation to HVLP and LVLP spray guns.
To me, this is not an argument about what is right or wrong, but personal preference. Good results can be obtained with either solvent based or waterborne finishes.
Re: Why I chose waterborne
Stephen Roth
I had a similar internal debate about choosing waterborne over solvent finish. I am a hobbyist woodworker, but solvent fumes in the home setting can be even worse than in the business setting (insurance, neighbors, family, solvent storage, living with the solvent fumes, etc.)
But another reason that tipped the decision for me is that I think the finishing industry is going to go fully waterborne within the period that I will be doing spray finishing. We all know that woodworking skills often have a learning curve, some longer than others. And finishing has an even longer curve because you don't do it as often.
So I figured that I would "future-proof" my skills and equipment by starting with waterborne.
I use General Finishes, and between their Enduro-Var, High Performance, and Transtint, I can dial in a finish and sheen that I think matches solvents.
