How wide of a gap?
Joe in a Cleveland suburb
How wide should I make the gap between these door doors?
They are each 12" wide x 32" tall
Thank you.
How wide of a gap?
Thank you.
Re: How wide of a gap?
Sgian Dubh
1.5 - 2 mm across the top, bottom and where they meet. You ought to apply a small bevel to the central meeting edges of both doors. Slainte.
You have to get up pretty early....
to get ahead of Richard.
Exactly. What he said.
I was going to say less than an 1/8, more than a 1/16" with a back bevel to allow them to clear as they swing open, but I was thinking in Amuricain.
door gap
You first question needs to be how to achieve the door gap? I don't see hinges so your are not ready yet.
I will begin with a disclaimer, I have never fit a door where I was entirely satisfied with the result. Maybe this result is a result of how I do it. So lets begin there, with the expectation that others will offer their advice which might lead to a better result.
Mortise for the hinges on the oversized doors. Properly mortised the screws only hold the door in place. They do not determine its position, so this step is critical. Install with one steel screw 1/8" shorter than the final brass screw length you will use. Close doors and determine what the overlap is in terms of how much and does it taper top to bottom. Remove doors from cabinet and hand plane from each door an amount that will just enable the doors to be installed in the closed position. Examine the gap or lack of it. Remove doors from cabinet, or at this stage just one of them, and plane some more to get the gap that looks good. (final fitting can be done on only one door if only smidgens are being removed. You can't detect 1/32" difference in a door frame width.) Too close will look better than too big and 1/8" is way too big.
Finally bevel one or both doors (depending on whether you arrange for either or a determined door to be opened first) so there is clearance when closing the last door to close, or first to open. Install all the screws.
Re: door gap
"I don't see hinges so your are not ready yet."
They are on order. Leaving for GA a week from this Saturday. Hoping to take this with me...
Thanks.
time line
You can not possibly have the finish hard enough to travel in this time. You will get to enjoy it at your house until the next trip and thank me for encouraging you not to rush it at this stage. Fitting doors is fiddly and a poor result will bother you for ever more. Take the time to do it right, including finish.
Dick Coers
In the climate where I live, I build in a gap the thickness of a nickel in the winter, a dime in the summer. Can you tell I was taught by an "old timer"? I hand plane in a slight back angle on the mating stiles.
climate change
This is a frame and panel door. The gap should not change with season.
Re: climate change
Glass is going in the doors. Which reminds me, I need to get glass too... oh and turn knobs. Uhg.
Take Bill's advice and delay delivery.
Ah, but...
...it will change slightly, like the difference between the thickness of a nickel and a dime.
Stiles have width. The four stiles on those doors appear to add up to at least 8 inches in total width, which, multiplied by the expected movement coefficient of cherry between 12% and 6% MC, will change the gap season to season. This movement will decrease as time goes on, but it is not zero.
Elli
The stiles look flat sawn to me
Dick Coers
That means a little change in 4 stiles to change the fit at the mating gap to me.
Re: The stiles look flat sawn to me
Yes. Flat sawn. That's all I have/had left.
I wanted to use quarter sawn but none on hand. Pretty much down to just scraps now. It's difficult for me to get cherry. Any wood for that matter actually.
Brad Chenoweth
Hi Joe,
Not sure if you're east or west side, but I've bought material from Homestead Hardwoods out in Vickery, off Rt. 6 west of Sandusky. I haven't been out there in a while, but he always has a good selection, and fair prices. Nice folks, too. It takes me probably 50 minutes or so, from Elyria.
Hi Brad. West side suburb.
Yes I know that place. Nice place. I've been there a number of times. My parents used to have a house on Catawba Island. My dad had a woodworking shop there and we would go to Homestead for lumber.
My problem is I don't have a truck and I don't know anybody with one. My hope is to, in the next couple months, rent a truck and get a good load that will last me a while or pay somebody to deliver to me.
There's a place in Columbia Station that's pretty good too. They say they can deliver for a price. Haven't looked into that yet. Back to Nature Oak. http://btno.net/
Re: Take Bill's advice and delay delivery.
Yonak
Putting it back-side-down on a plastic tarp it should be ok. It will be inside an SUV or van, right ?
Agree
I have numerous glass panel doors in our house and I can not deny that the gap may vary some amount. It just is not noticeable to me. I certainly never had one fail to close in the summer.
Yep. Small SUV. 14 hour drive.
Are you sure
In 7 days install and fit door, stain If staining), 1st sealer coat of varnish, cure enough to sand, 2nd coat varnish which could be enough or not, then get varnish hard. I could do it with lacquer or conversion varnish. But alkyd varnish at 70 degrees or less?
There are finish alternatives.
Grant Smith
Wipe on poly can be applied to a fine finish and be mostly cured in maybe 3 days. If you think it is an unsatisfactory product, I have seen poly finished work win juried contests.
The key is not to follow the directions on the can, and instead wipe on and then wipe off with another rag, repeating until proper film is built.
In commercial settings, lacquer is often used for expediency. Sealer and lacquer finish hard enough to travel in a couple days max.
Just a thought.
Re: There are finish alternatives.
Thanks.
I actually plan on doing a wipe on. It's the only finish I can do without horribly messing up.
