need advice, desk
need advice, desk
need advice, desk
The three boxes on the top are shown upside down due to gravity interfering with the picture. The horizontal unit bridges across the top between the two vertical units. \\Question: How to fasten the middle unit to the two ends so that it can be taken apart to move it, then reliably reassembled?
Re: need advice, desk
Buck Nall
Upside down means the entire thing is setting on the cabinet.
OK, fit a pice into the top of the top/side boxes, both ov'm
Screw/glue pices to top of boxes.
Ueaw its confusing "upside down"
Lay board all the way across top.
Screw last board to the pices U fitted into top of 2 boxes
**Maybe somebody with some education will explaine a better way!
It's supper time heaw in South Ga.
Don Orr
Connector bolts ?
what is a Connector bolts ? If the name is the function indeed that is what I need.
Consider using Threaded inserts. I am using some form Rampa Tech that seem to work very well. Drill a hole slightly over 3/8", maybe 10.5 mm, screw in the insert and then you can bolt the piece together with machine screws. The advantage is that you can remove and install the bolts as often as necessary without wallowing out the holes as you would with wood screws.
I am using them on the table I have been beavering on for several months. Since it will weigh about 300 lbs. I wanted to make it possible to completely disassemble it.
Alan Young
Connector Bolts *LINK*
Alan Young
I made my own for use on this table
it seems just easier to give the whole fabrication page on my shop made connector bolts. scroll down a bit and you'l see the brass pieces then how they are employed
-Alan
Connector Bolts on a Dining Table
Agree.  Threaded inserts.
Connections
Connector bolts (aka, Sex Bolts ) would be a good bet, as would threaded inserts.
Re: Agree.  Threaded inserts.
Wiley Horne
Like these...
https://www.amazon.com/Z-LOK-400-3-CR-Installation-Stainless/dp/B015CAPC14/ref=sr_1_29?dchild=1&keywords=Threaded%2BInsert%2Bknife%2Bthread%2Bm4%2B-rivet&qid=1616122088&s=industrial&sr=1-29&th=1
I would consider combining the threaded insert with shouldered, knurled thumbscrews. And just let them be visible—with her permission of course. You’ll have visible hardware either way, so this option is to use handsome hardware and make it a feature.
Or use hex head screws, with wooden caps fitted to cover them.
Wiley
Bruce, a MN Galoot
Installed via a drill press to keep them square to the surface.
Oskar
tapered sliding dovetail battens?
Ikea knows
Tom Dunlap
Ikea has solved this in many clever ways.
Jason Roehl
https://www.amazon.com/Furniture-Fitting-Pre-Inserted-Wardrobe-Connecting/dp/B07WTKV8CQ
How a LOT of office furniture is put together. Can be mostly hidden.
Jason
No DP required with the ones....
I recommended. One of the "features" of the Rampa Tech ones I used is they go in and remain nice and straight. I drilled the holes and chamfered them slightly and drove the inserts home with a drill and hex shaft. I have about thirty of them in this table I am working on and being out of plumb was not a problem with any of them.
OTOH I learned the hard way you do have to be VERY careful positioning them.
I bought a fifty pack and will have a few left over. I could send you some if you want them.
Re: Connections
Ummm, a "sex bolt" for a granddaughter ! Available at one of those stores advertised along I-95?
In spite of the name that seems to be just what I need. Now to find it in brass.
Buck Nall
Well everybody knos I displayed my IGNORANCE with
bill's advice about his question of dismantling & reassembly
PERSONALLY I'd still do it MYWAY, !!!!!!!!!!
Yall have a goodern.
anyone know where I can find in brass
Seems these connectors are called a lot of names, making it hard to search. I would like to use a connector bolt in brass if I could find it. LV has black which I can live with, which I found unnamed under knock down hardware.
Kneale Brownson
Re: cross dowel barrel bolt
kneale brownson
You could install cross dowel barrel bolts: https://www.fastenright.com/general-fixings/cross-dowel-barrel-nut/ff04
If this were my project, I'd make the top and two sets of drawers as separate pieces held together with tabletop clips or figure eight top fasteners.
Re: No DP required with the ones....
Bruce, a MN Galoot
Thanks, but they’re not in future projects for me. I appreciate the offer, though.
Like this?
Wiley Horne
https://www.homedepot.com/p/Everbilt-1-4-in-x-1-3-16-in-Narrow-Brass-Connecting-Bolt-817928/204281649
Scroll down to fond the matching cap nut.
Wiley
My Bad, I was talking to Bill, the OP
J Barrett Irby Jr
But if you NEED some I would send a few.
Don Orr
https://www.amazon.com/Anmas-Length-Furniture-Connector-Socket/dp/B07QQ1LTMS/ref=asc_df_B07QQ1LTMS/?tag=hyprod-20&linkCode=df0&hvadid=343209932543&hvpos=&hvnetw=g&hvrand=8507254778974539228&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004743&hvtargid=pla-767469716100&psc=1&tag=&ref=&adgrpid=68249716799&hvpone=&hvptwo=&hvadid=343209932543&hvpos=&hvnetw=g&hvrand=8507254778974539228&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004743&hvtargid=pla-767469716100
Like this. They come in many sizes. Or as Ellis said.
