Ruhlmann Veneering
CJ in MPLS
Hello all.
I am curious about when veneer is applied in the process of making a Ruhlmann chiffonier with a harlequin pattern. Other than the simple and correct (yet unhelpful) "more than 100 years ago", I am wondering when one might apply veneer to a cabinet to obtain this seamless appearance? As an example, please see the cabinet below.
The legs and stretchers are veneered. I expect that the structure would have been mostly/entirely formed before veneer was added. Would the cabinet components have been veneered in a disassembled or in an assembled state? Hammer veneering or clamping?
For the harlequin pattern of the door and side panels, I expect that the veneer diamonds were cut and taped up into a sheet for application. I was wondering about the stringing however. I have seen some stringing that has been added to the periphery of a taped up veneer panel, usually as a border. However this seems to be a bit problematic in this harlequin pattern. Would one simply use a straight edge a 1/16" router bit to form this pattern? I expect that the little dots were drilled and emplaced after veneering.
Thoughts?
