Epoxy observation....(OT?)
J Barrett Irby Jr
I have been posting about my miserable adventure pouring epoxy into the cracks and fissures of the table I am working on.
I tried taping the cracks on the underside with some incredibly sticky flashing tape. It failed. Leaked everywhere. I tried taping with packaging tape. Failed.
On the top of the boards I used latex caulk to make a dam around the openings to allow the epoxy to pond and mound up a bit. That sort of worked but the caulking came loose over time.
On my final (I hope) repair I use double stick tape on the top because it had a layer of foam in it and enough thickness to allow for the ponding. Pressed it in place with a J roller. It contained the epoxy, but when I removed the tape the epoxy had soaked out under the tape and almost escaped.
Apparently the the epoxy has such a wetting action it soaked into the bond between the tape and the wood. Maybe the tape on the bottom had just enough additional pressure on it to actually leak. Wonder if the warming of the epoxy as it set cases the leaks?
Now I know why the "Pros" on YouTube Build a tray to put the entire piece in and line with with packing tape or Tyvek tape and seal all the joints with silicon and flood it with epoxy. My problem with that was that the little bit of epoxy I used cost $50, not the hundreds are spending. While I did not spend hundreds on epoxy, I have many many hours sunk in compensating for the leaks and patching places that did not fill up.
