The patron Saint of us ignorant people
J Barrett Irby Jr
Some of you know I have been posting about make a slab table and filling some of the voids with Epoxy. Here's your chance to spot my mistakes. I put a sheet of plastic like you see on commercial bathroom walls under it in case it leaked, knowing the epoxy does not stick to HDPE. I had some Butyl Rubber tape that can be used to seal skylights and the like. I taped the bottom of all the cracks with this super sticky gooey stuff. Poured in the epoxy. The type that takes as much as 48 hours to gel. It started leaking. I put on a bunch of clamps. Sat a pitcher under each of the tow laces it was draining out. Once and hour I would go to the shop and pour whatever was in the pitchers back into the cracks. Even got up at 4 am for one last attempt and then gave up.
Anybody spot the two mistakes?
Yesterday I turned the slab over and tried to remove the plastic. Tried being the operative word. Epoxy may not stick to HDPE but it bonds ferociously to whatever that stuff was I had. And it never occurred to me how hard it was going to be to get the butyl rubber off. Its not meant to come off. I spent hours picking at it. Tried scrapers. Chisels. Heated it with a heat gun. chilled it with ice. Called 3M Technical, not help. They tried but had nothing.
I spent hours. Two days. Got the white plastic off with a heat gun and a chisel. Finally occurred to me to oil the chisel to keep it from sticking to the butyl rubber and peeled it off.
So my patron Saint is Upid.
Re: The patron Saint of us ignorant people
Next time...
John in NM
Just use masking tape. Not blue (or green :D) just regular cheap masking tape. Use lots and go far past the void edges. Works great, I worked in a mesquite shop for a couple years and we did a lot of this.
We also used 2 hour epoxy rather than longer cure. Just more time to leak the longer the cure. Large voids you use less hardener as the epoxy is usually exothermic and large masses will go off quicker. The quicker they cure, the more likely you are to get cracks on cooling or even bubbles if the stuff boils (seen both).
Re: Next time...
J Barrett Irby Jr
Isn't hindsight wonderful? /the stuff I stuck on there is not tape. It does not have paper or fabric reinforcing in it. It did not dawn on me that there was no way to peel it off until it was too late. The guy at 3M was pretty funny, he gave it thought and check his research and checked with his fellows and finally said It's not designed to come off.
I went on YouTube and found lots of videos on "10 Things Not to do pouring epoxy". Most of them mentioned Do not try to tape off the bottom. Lots of people said to build a form and flood it top and bottom and just get it over with. At the cost of epoxy I could not stand that idea. That looks like a better idea now.
I could have poured a 1/2" of 2 hour stuff in the bottom and then topped it off with the good stuff.
WHY
were you using such long hardener? I do what you're doing all the time and have no issues with 3 hour hardener. I paint the reverse side with Anchor Seal wax and while wet apply plastic food wrap. I put the piece on a flat surface with a layer of paper towels to give a bit of pressure.
Any leaks get controlled within a short distance from the crack and the paper and plastic come right off.
William Duffield
I use clear plastic packing tape. The flatter you can put it down, the better.
the epoxy will seep into any wrinkles, but if you flatten them with a J-roller, not much will work its way in, much less, escape, and you can easily scrape or sand that off. It peels right off when the epoxy has kicked, leaving a flat, smooth surface. Any places you don't have any wrinkles, especially on the bottom of your slab, are now finished. Any little ridges left from tape overlap sands or scrapes off as easily as tracks left from hand planing the surface. The dispenser for strapping cardboard boxes is very convenient, because it leaves minimal wrinkles.
I think the epoxy you want to use is made by Alumilite. It is significantly less expensive and more flexible after it cures than West System.
Re: Alumilite
William Duffield
Alumilite makes several epoxy and other resin products. I think what you want to try is called "Amazing Clear Cast."
Of course, you are also going to need the Part B. :)
Mark, how do you ....
Get the wax off? Doesn't it interfere with any finish you might treat the underside with?
I like this idea. Just wondering?
Easy
When it sets up overnight, peel off the paper and plastic and then use a scraper. Any epoxy "spread" comes right off and most of the wax does as well. Remember, the wax does not penetrate the wood and Anchor Seal retains the emulsifier so the rest of the residue comes off with water and a scrub/rinse.
Re: Next time...
Ralph Lipeles
In addition to the tape, depending on the sizes and shapes I use pieces of wax paper. I tape pieces of the wax paper, where I want it, with masking tape. It works great
William, this is all your fault...
I went and looked up Alumalite with Google. Now I am getting ads for it on Facebook. That and every other epoxy as well. They're on to me.
Re: William, this is all your fault...
William Duffield
Don't blame me! I'm not even getting a kickback. :D That arrangement is between you and Google. People I know who are paranoid advise clearing your cookies after every internet session and setting up a VPN. It would probably help to also wear a tin foil hat while browsing.
Tin Foil
Doesn't work!!!
Aluminum, however, is a different story provided they're broadcasting on the proper frequency. You must be adamantly grounded and avoid facing west between the hours of 3:45 and 6:13 pm.
Or.....
John in NM
Don't use google if it bothers you :D
Other search engines are gaining popularity, simply by being "not google"....
Re: Tin Foil
William Duffield
Of course you use aluminum foil. "Tin foil" is just a figure of speech, I would guess derived from the Tin Man in Over the Rainbow. It probably really works, in some fashion, as a Faraday cage.
Check
with Magneto
Result
After the Anchore Seal wax is scraped and scrubbed off and a bit of sanding, I got this with a Red Maple crotch
