FINISHING REDHEART
FINISHING REDHEART
FINISHING REDHEART
GORDON P PATNUDE
I am in the process of making a walking staff for a client.
The wood is Redheart. The final diameter will be about 1 1/2". It will be "decorated" with 3/8" ebony pegs.
I understand that Redheart, and several other exotic hardwoods, will not retain it's fresh-cut color over time after finishing.
I have been considering using one or more coats of red TransTint in clear shellac to dye the wood prior to applying several coats of satin polyurethane.
Have you tested this kind of treatment on woods like purpleheart and other exotic hardwoods that lose the fresh-cut color and turn brown over time??
Re: FINISHING REDHEART
You need to be more specific in the question you need to ask. Have I used dye stain on wood, the question you asked? Yes. But I doubt that answer is what you were looking for.
Dye stain
Redheart, or chakte kok, turns reddish brown upon exposure to air and light. Dye stain treatments work best on woods that bleach or lighten, such as walnut; but, if the underlying wood is getting darker, the stain will not be able to mask the darkening effect very well. Since redheart doesn't get as dark (relatively) as padauk or purpleheart over time, the dye stain stands a chance of maintaining at least some of the early vibrance. I've never tried it, so this is just an educated guess.
Re: Dye stain
He didn't say what he wanted the dye to accomplish. I suspect preserving the original color. That won't happen. Or, targeting what color the end product needs to look like by adding dye to something already colored will be similarly elusive. One can certainly add dye and wind up with some color different than not adding dye.
Wiley Horne
I have tried shellac (without dye) over freshly planed padauk, but it did not stop the oxidation. The alcohol in the shellac did elute some bright red color :) , but that was not the cause of the darkening.
Dye would not stop the oxidation, and would face the added challenge that you can dye a light wood darker, but it’s slim or no chance to get a dark wood lighter using bleach/dye combinations and maintain any vibrance.
Doubt it will work, but why not try it and see what happens?
Wiley
Jim O'Connor
I have made several canes and walking sticks from willow to exotic hardwoods but I always try to get the final diameter to around an inch due to the weight. A heavy stick won't be used when walking for any amount of time. I don't know Redheart but I suspect an 1 1/2 stick will be on the heavy side.
Agree
I don't have an official stick but occasionally cut one from saplings at hand if navigating difficult terrain. Such sticks naturally taper. I choose something < 1 1/4" for the top. Even 3/4 is plenty big at the bottom. I wear a size large glove.
