THE WOODRAT IS BACK!
End Grain Cutting Board
Don Stephan
A good friend, a relatively new woodworker, made a pair of end grain cutting boards and asked me why they warp and straighten, warp and straighten.
He alternated cubes of black walnut and hard maple, about 1 3/4" on a side. He ripped strips from 2 year old lumber, jointed and drum sanded the surfaces, glued alternating strips together with Titebond, crosscut, then glued the crosscuts together. Leaving each cuitting board laying on the assemble table, the next day they were cupped. Turned them over for a day and they straightened out, then cupped in the opposite direction. He send me a photo, and I noticed the individual cubes were a mix of quarter and rift grain, and sometimes the grain orientation was consistent across the width of the cutting board, sometimes not.
Understanding Wood by Bruce Hoadley suggests the two woods have very similar tangential and radial wood movement factors. He is tempted to wait for the cutting boards to flatten out again and wipe on several coats of tung oil, to try to minimize moisture movement into and out of the wood.
For my friend Grant, has anyone made end grain cutting boards of alternating woods? Did you have the same experience? Did you select boards that allowed all the blocks to have the same grain orientation (quartered or rift) and assemble with consistent grain orientation?
Thanks in advance.
Re: End Grain Cutting Board
Oil will not change moisture absorption much
Alan Schaffter
All my cutting boards are made from end-grain- hard maple, walnut, cherry, and white oak. I use Titebond III. All wood is dry, most has been in my shop for several years. All are of the 3D type cutting boards requiring multiple cutting, glue-up, re-cutting steps. Unfortunately, I don't have any pics on accessible sites.
Alan Schaffter
Found them. Here is the latest:
wet wood
Moisture gain or loss through end grain is rapid so equilibration with ambient air is rapid.
I have made lots of end grain boards from KD wood and they stay flat.
Put the boards on edge and let them dry out
I like 'em.  Very attactive.
Pete in Holland MI
Sounds like wet wood. Where was the wood before he started working on it? Outside? Ambient climate outside, especially the winter, will be different than in a heated house.
Assuming his wood is deemed dry, if he has more to do in the future, rip all the strips to rough size. Stack them to allow the air to travel around for several days. Finish machining to size, and then glue them up.
Don Stephan
Thanks for the input. I suggested stickering and letting the board strips rest for a few days after first flattening and straightening, but he was concerned about the two he had already made. Passed along the suggestion to let the wood dry more and see what happens.
