THE WOODRAT IS BACK!
Removingn broken screw ?
Michael van pelt
Small box hinge and I broke off one of the brass screws. Looking to order a screw extractor. Any recommendations of what kind works the best. Looked at Rockler hollow screw extractors and the 4 piece set of regular ones from Lee Valley. Appreciate some guidance. And yes I had pre drilled used wax and used a steel screw first. Darn thing just broke! Ugh. Thanks
Re: Removingn broken screw ?
Extractor's easy to make with a drill press and a piece of rod with a diameter a bit bigger than the screw. Drill a hole in the end then use a countersink to taper the hole to get a sharp outside edge. Lastly file a couple of teeth. Chuck in a drill and drill the hole which you fill with a bit of wood. Here's a sample
Jack Guzman from Maine
great tip
Virgil Johnson
A steel roll pin can be used in the same fashion that Mark mentioned. These are heat treated and hold an edge better than a regular steel rod. As a bonus they come in various sizes. Grind the teeth with a Dremel cut off wheel. Just remember to make the teeth so they cut in the CCW direction.
Ralph Lipeles
When using small delicate brass screws it is often best to first use a steel screw with the same profile as the brass screw.
I've found grinding a tooth on a roll pin works
Michael van pelt
Ralph. Did you read my post. Did you read my statement?
Suggestion....
I have repaired/replaced dozens or hundreds of screws that were in holes that were wallowed out. I drill the hole out to a known size and cut a plug out of similar wood with a plug cutter and install it in the hole with glue and then start over with a new screw. This is much better than a dowel or tooth picks because the grain orientation is correct.
