Propane Safety First sort a OT
Mike L
I have always made it a habit to turn off the propane bottle even if I am going to use it again in the next hour or so. Today while working in my garage I heated it up with the protable propane heater. When it got warm enough I shut it down and turned off the bottle. About twenty minutes later I placed a portable jointer on a table. Turned and walked away. A few minutes later the table top fell off the base and the jointer landed on the regulator of the propane tank. It sheared it off like a hot knife though butter. If the tank had been on I would have propane spraying straight from a 20 LB bottle into my garage. The only damage was the high pressure regulator needs replaced and the jointer needs a little work along with a busted knob. Now to fasten down the table top so it won't happen again.
